External Blu-ray writer
Dear Sir,
As I know Sony DVD VRD-MC6 do not have HDMI input so it not possible to record your video direct from iphone . but I phone has support to hdmi output thru iphone to hdmi cable and your Sony DVD VRD-MC6 has AV input so you need a one another device which call hdmi to AV converter it will work but your video quality will compromise.
If you want to record video form computer you need external dvd writer and one dvd burning software
After that you just copy your iphone videos thru usb cable and burn thru dvd burning software
SOURCE: how can I export pictures from my computer to sony vrd-mc5
pls read this link :
http://www.crutchfield.com/S-gIufiXZNdM2/learn/reviews/20071113/Sony_VRD-MC5.html
hope it helps.
SOURCE: with sony dvdirect vrd-mc5, can I burn pictures from my computer
Yes and no... you can not hook it up directly to your computer and burn copies of pix. You can however transfer your pictures to a memory card (SD, MS or CF) and then put that in the VRD-MC5 and burn your pix.
Hope this helps!
SOURCE: I need to have access to the manual for the sony vrd-vc20
Hi and welcome to FixYa,
Initially, try here. You would need Adobe Acrobat Reader to view this file.
Pls post back result(s). Good luck and Thank you for using FixYa.
SOURCE: Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
SOURCE: I recently received a sony VRD-MC6 and tried using
Mine doesn't see the signal till a disk is inserted, but I have another problem, mine won't finalize the disk after recording.
