SOURCE: Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
SOURCE: what type of indoor antenna work best with this unit?cobytv/tf-tv
A simple pair of rabbit ears (standard dipole antenna) should do the trick. You will have to set the source input to NTSC/ATSC and connect the antenna to either the analog or digital F- connector inputs if you use a RF splitter you can use one anatenna for both inputs. In any event try this first.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: How to connect an AKAI LCD tv to an INDOOR
Put tv on air, connect antennae to the coaxil input on back of tv.
You can also go to tv's menu and find the "autoprogram" feature and select it. Let it run thuroughly until it is done searching all available channels. Tv. may need to be on channel 3 or 4 to use the antennae/converter box
SOURCE: Is the Panasonic PT50LC13 tv HD readt or do I need
This televison is HD ready in the fact that it can produce and HD picture. But, you will need to have and HD tuner source or a converter box to get HD signals.
I am doing this for free so please vote as best you can.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
