Question about Bush Televison & Video
I have a bush smart digital tv recorder its worked fine then i went to watch something ive recorded and its saying its disabled ive tried everything and cant get it to work can you help
Posted by TRACEY BROOKES on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: recording disabled
guys hope you all found the solution like me who had same issue. if you noticed, it says about the aspect ratio and that means the formated disc aspect ratio is not compatible with the aspect ratio your camera need. so re-formating the dvd with right aspect ratio solved the problem quickly and we have peace.
bayaraa
Posted on Jul 05, 2008
Anonymous
SOURCE: Any idea why my lifecam wont record video?
REQUEST FOR MY WEB CAM CAMERA
Posted on Feb 06, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: how to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
Posted on May 29, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 17, 2009
SOURCE: dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
Posted on Feb 02, 2011
Trying to record on finlux smart TVs but it says no removable disk and initialisation failed . What do I need to do !
Finlux USB Recording Functionality - YouTube
? 1:40
https://www.youtube.com/watch?v=GKH-p6u0O8Y
Mar 26, 2014 - Uploaded by MyFinlux
Stay in control of your TV viewing thanks to our PVR functionality. You can pause live TV, or even record shows up to seven days in advance via USB. ... SEG 46" 46125 FullHD Smart TV Uydu Al?c?l? Kanal Ge?i?i ve Media Player ve ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
Finlux 32H6020-D 32 Inch LED HD Ready TV - Full Video ...
? 13:54
https://www.youtube.com/watch?v=pqfAs2kBKHM
May 10, 2013 - Uploaded by TheSuperUberGOLDFISH
Finlux 32H6020-D 32 Inch LED Widescreen HD Ready TV with Freeview & USB PVR Recording Black (New For ... Gadget Show Live 2013: Finlux 47inch LED Smart TV with 3D, £799 - Duration: 2:17. by ShinyShiny 12,627 views ... Terms · Privacy · Policy & Safety · Send feedback · Try something new!
Finlux Smart TV System 2013 Review ' AVForums
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
No signal on my bush 320GB satellite HD digital tv recorder
i have a signal while watching TV
But when i try to record it states no signal
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Hi, I have the dvr3006 dvd recorder, my tv is a
The dvd possibly only has an analog tuner so you would not be able to get a digi signal
16helpful
3answers
Sony Handycam says movie recording disabled. How did this happen and how do I undo it?
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
1helpful
Recording problem between dvd vcr recorder combi and hd lcd tv
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
2answers
Problems with my handycam
have you tried to clean the drum sometimes what you described is the result from a dirty drum.
1helpful
2answers
Recording disabled
bayaraa
Televison & Video Logo
Top Bush Televison & Video Experts
Raj Patel
Tom Chichester
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
