Question about Westclox Audio Players & Recorders
I just bought a westclox alarm clock. I programmed it but the date and day do not match. How can I fix this. It says Wednesday May 28 and it should be Tuesday May 28
Posted by Fran Zwaagstra on
Steve Pack
  • Westclox Master
  • 6,353 Answers
The year may be wrong, in 2002 the day and date match
Posted on May 28, 2019
5 Related Answers
Richard Finch
  • 397 Answers
SOURCE: Clock day different from date
This is probably a stupid question but you do have the year right in the date?
Is the date format correct?
UK day/month/year
USA month/day/year
Posted on Aug 01, 2008
Anonymous
SOURCE: Westclox Monarch Alarm Clock - Model No. 90003
While holding down the snooze bar that says "ALARM" on it, hold down either of the "HOUR" button to set the hour when the alarm should go off or hold down the "MINUTE" button to adjust the minutes for when the alarm should go off.  Switch the "ALARM" to "ON" when done.
Posted on Sep 03, 2008
Anonymous
SOURCE: Westclox Travel Alarm
After selecting either TIME, DATE, or ALARM at the top of the screen, use the stylus to touch and hold the large time display. Hold it there for about 5 seconds and the clock will beep and the time display will start flashing. Then you can touch either the hours or minutes and it will increase by either 1 hour or 1 minute accordingly. When the DATE is selected, it shows the year in the large display. Again, holding the stylus on the year diaply for about 5 seconds will enter into the chqange mode. IN all cases, to exit the change mode simply select one of the other selections across the top: TIME, DATE, ALARM.
Posted on Sep 08, 2008
Anonymous
SOURCE: Emerson Research SmartSet Clock Radio
I forund a solution at http://www.emersonelectronics.ca/emerson/en/product/view/14383
Posted on Apr 06, 2009
Leobreaker78
Charles Luhrs
  • 5 Answers
SOURCE: I have a westclox atomic alarm clock - model #700...
I have the same alarm clock the damn thing gives me a heart attack when I wake up. All in all I have the instructions for your clock.
Simple on the back of the device there are five buttons hold down the one that is labeled mode/set then the display will flash use the oC|oF/Up key or Wave/Down key to change the keys and the mode/set the to move between each field.
If you press (not hold) the Mode/Set key you can change the alarm, change the numbers using the degreeC|DegreeF/Up or Wave/Down key to change numbers accordingly.
To turn the alram and snooze function on or off press the Alarm/on\off key.
What I just said may sound complicated but of you press the buttons as I told you then you should have no problems what so ever.
Posted on Jun 03, 2010
I have just bought a Westclox travel alarm clock 70228 which I cannot get started. The battery works but I cannot get the nos. for date/time to work.
If you just bought it i would take it back from where I purchased it and see if they can set it. If not they should replace it. Take your receipt with you.
Jan 08, 2019 • Home
How to set alarm for Westclox 47550 Quartz?
Hi, A 8 year old can do this. On the back of the clock there should be 2 round turning nobs. 1 is for to set time (min...) 2sec is for to set timer for that hour...usually is a smaller hand on face of clock.
select hour to wake up at and set alarm Button. This is only basic set up.
How do i set year on westclox 70034 alarm clock?
You need to make certain that you have set the year right, otherwise it will show the correct day for say 2011, rather than 2013.
Calendar/clock keeps changing to wrong date (Nokia 6220 classic)
ok mate its probly ur settings ave ya got it on manuel and if ya do dat wud probly be the problem switch it to auto update and time and that shud do it for ya tell us if it works for ya
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
25helpful
2answers
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
