Nothing no info at all --generic answer --in most its located in freezer section behind wall panel with the evaporator
After you unplug the fridge. there is a pump that cools the fridge with coolant however there is also a fan that blows on the pump to keep it cool these can usually be found behind the fridge in the back, there may be a piece of card board covering it that can be removed. there are also coils that will collect dust on and around the pump you can use a bottle brush type cleaner on these coils also a vacuum cleaner with an extension nozzle can be used to pick up dislodged lint and dust note that the cleaner these coils are kept the less the fridge will have to work to keep things cold. unplug from power first.
SOURCE: kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
SOURCE: freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
SOURCE: no air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
