Unable to get sound from speakers/woofer. Can listen to radio and cd via headphones. Everything works. That's it. Any thoughts.
Posted by Stephen hughes on
Franco Dosil
    Top Expert:
  • Audio Player... Master
  • 10,535 Answers
Hello Stephen, indicate brand, model and type of equipment that you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Stephen, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Posted on May 28, 2019
Testimonial: "Hi Franco. Thanks for replying. It is a Ferguson F5000DAB. DAB MICRO SYSTEM with Docking for Ipad."
  • Franco Dosil May 31, 2019
    Hi Stephen, well, it's a Ferguson F5000DAB, I looked for service manual and I did not have positive results
    As you comment, it would seem that the outputs, are either muted or damaged, you can listen through headphones because the F5000DAB, has an amplifier for that use
    Test, disconnect the speakers from the equipment and test one speaker at a time, this is to know if there is a speaker wrong and that could cause the failure
    If you try everything and you do not get positive results, I recommend you seek a specialized technical service
    I sent you the link to download the user manual
    I hope you can solve the problem
    Hola Stephen, bien, es un Ferguson F5000DAB, he buscado manual de servicio y no tuve resultados positivos
    Por lo que comentas, parecer?a que las salidas, est?n o enmudecidas o da?adas, puedes escuchar por auriculares porque el F5000DAB, tiene un amplificador para ese uso
    Prueba, desconectar del equipo los parlantes y probar de a un parlante a la vez, esto es para saber si hay alg?n parlante mal y que pueda ocasionar la falla
    Si pruebas todo y no consigues resultados positivos, te recomiendo busques un servicio t?cnico especializado
    Espero puedas resolver el problema
    http://dl.jehandleiding.nl/new/external_...
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
Anonymous
SOURCE: no sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Posted on Feb 01, 2009
darjr
Darial Jr Lasaria
  • 379 Answers
SOURCE: Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Posted on Jun 01, 2009
Anonymous
  • 5 Answers
SOURCE: Logitech THX Z-2300 Speakers Don't work and subwoofer does
Well, just because someone at Logitech said the speakers are definitely broken doesn't necessarily make it so. They told me the same thing, yet when I read on another forum that plugging earphones into the wired remote sometimes seems to make things better, I plugged earphones into the wired remote -- and Voila! All of a sudden the blue light went on and I had sound from all three speakers. The sound continued working properly even after removing the earphone jack. IMO the problem could be with the wired remote rather than with the speakers themselves. My speakers work again!
Posted on Jul 23, 2009
Anonymous
  • 8 Answers
SOURCE: my speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Posted on Aug 01, 2009
Radio and cd work ok but no woofer speaker, only tweeter on right side fron and rear
Andy check speaker connections and wire for damage, hook up a temp speaker to see if it fixes the problem, if it does replace speaker, if it does not, then there is a problem with radios amp.
to show your appreciation press the helpful button and follow me on fixya for more tips and info.
Feb 15, 2016 | Cars & Trucks
I can only answer my mobile via speaker or headphones. Want is wrong?
Rosemary
Sorry it isn't working. Sounds like the earpiece is broken. Please contact us. CONTACT US to locate a service center.
Mark
Motorola Support
Jan 08, 2015 | Motorola Mobility Defy Mb525
Hitachi 42 PMA400e Plasma Tv.
Just get a headphone jack that does not shut off the speakers and have your dad plug his headphones into that.
Mar 22, 2017 | Hitachi 42PMA400 42 in. Plasma Television
Headphone for DVD on 2006 Chrysler Town and Country
Just found this and it worked! Hope it does for you as well:
There should be a button on the DVD remote control with a headphone symbol on it. Make sure the headphones are turned on(red indicator on earpiece) and push the headphone button on remote. The headphones will only work in the back seats of the vehicle. Once you have audio to the headphones, you should be able to hit the AM/FM button on the radio and listen to the radio while back passengers use the headphones for video.
Apr 04, 2012 | Cars & Trucks
My compaq presario c700 speakers dont give sound however i can listen sound using headphones. Is it some hardware problem in its inbuilt speakers? I have windows 7 ultimate OS.
Hello and Welcome to FixYa!
If you can listen to sound from any other means, as you said via headphones, then the Audio drivers are working ok. The issue is with your Hardware unit; i.e Speakers (The In-built speakers).
I hope you are getting the picture.
Concerned, Nooh
Aug 11, 2011 | Computers & Internet
I have a problem with my Yamaha HS50M's. When i play a song with a punchy bass line i get a crackling noise but i don't think its coming from the woofers, what can i do to resolve this or does this mean...
First off make certain it's not coming from the amplifer, try listening via headphones. If that is OK switch the speakers. If you find the sound moves to the other channel with the speaker it is the speaker and not the amp. The next thing to do is closley examine the faulty speakers units looking for damage. Still nothing, then with your fingers spaced out over the cone of the woofer (so you apply pressure evenly). Push on the cone gently so it goes in and out. If is scrapes at all you have a cone that is catching. I'm afraid the woofer must be replaced. If it doesn't catch, your next step is to open up the speaker and look around for damage or bad soldering.
Oct 01, 2010 | Yamaha HS50M Main / Stereo Speaker
Dvd player
If you have a factory DVD player, then while the DVD player is on, press your radio preset numbers' 2 and 4 simultaneously. Then to listen to the CD or radio just press whichever button you want to listen to. You should hear sound out of your front speakers only, and won't interrupt the headphones. Good luck.
Nov 02, 2008 | 2005 Ford Freestyle
No sound from speaker
If the volume is adjusted when the headphones are plugged in I'd be looking at the speaker. It may need replacing. I don't know if the headphones are run from a preamp or attenuated via the audio output IC. If it's run from the preamp then the main output could be kaput. Check the speaker and it's wiring first and go from there.
Jul 22, 2006 | Freeplay Energy S360 AM/FM/SW/DAB Radio
26 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
