Question about Sharp Audio Players & Recorders
Need help restoring sound to sharp ht-sb60 sound bar
Posted by Michael Muse Sr. on
4 Related Answers
Anonymous
SOURCE: I remove bye mistake need help to restore
no sound on a sharp mts stereo tv
Posted on Jun 14, 2010
gopakumarg43
  • 76823 Answers
SOURCE: i have a sharp aquos
Hello
What is the probelm do you face with your Sharp HT-SP300. Give me some more details by Fixya please. OK.
Posted on Mar 11, 2011
  • 6412 Answers
SOURCE: Hi.How can I connect SHARP HT-SB400 sound bar
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Posted on Mar 05, 2012
gopakumarg43
  • 76823 Answers
SOURCE: I have a Sharp HT-SB60 for 12 months the subwoofer has suddenly stopped working red light keeps flashing. Can you please advise me what I can do to fix this. Thanks
Short circuited component/s at its output section circuit. Contact any service technician. Gopakumar Gopalan Google
Posted on Dec 21, 2014
Hello there I have a HT - sb60 soundbar that I'm trying to program to my co5 remote having difficulties can anybody suggest something
I already answered this, but for others, here it is again.
Hello Michael
You are always better off starting your own questions rather than tagging to an existing one from January 2014. (you did this, well done) Your question is lacking vital information which leads to us having to guess. Questions must always have FULL 'make model (what it is)'.
Saying 'HT - sb60' leads me to guess you have the Sharp HT-SB60? So then I go off and search 'Sharp sound bar remote code' and I find this. The code is always based on the device it is controlling.
0066 is your code
Soundbars: Setup and Code List
Brand SHARP. Code 0066.
'cl5' on its own leads me to believe this?
Philips UNIVERSAL remote control SRP9232D/07 CL5 (T223A)https://www.ebay.ca > ... > Remote Controls
Find many great new & used options and get the best deals for Philips UNIVERSAL remote control SRP9232D/07 CL5 (T223A) at the best online prices at eBay!
No sound coming from sound bar how do you make them compatible HELP
Use the fiber optic connection. Some TVs have this. All your programming inputs will sound. Matt of Martins TV Repair.
2answers
Need a service manual
Sharp seem only to have a user manual, no service manual. If broken it is probably not economical to repair.
http://support.sharp.net.au/downloads/opmanuals/HTSB602_om.pdf
1helpful
Sorry i am french, can not get sound from my sound bar sharp connected to my LG tv I think i dont know how to connect it all together... That´s mean the receiver, play station, blue ray sharp and the Sub ?...
I'm no good at French, but perhaps you manage anyway.
I used this on Google "sharp HT-SL70 manual" because I don't know the French word for manual. I did find manuals form Sharp in different languages, but not in French. So perhaps you try this yourself. Don't open the first links, where it says manuals on line, because they want to install malware. Only open the Sharp links where you already see PDF in front.
What remote can be used to control a HT-SL75 sharp
Features
Other than the cool things you can do when setting up the Sharp HT-SL75 system, there are no features to really play around with. This means no screen, no extra options to tinker, no virtual surround sound, no Wi-Fi and no Bluetooth. It is meant to be connected to the TV and it just works from there. No remote control is included either since you can simply use the TV remote control to adjust the volume.
I cannot get sound when connect sharp sound Bar HT-SL50 to a Sharp LC60LE835U
You have to go into the sound setup menu and select which audio out you are using. Select either digital or fiber so the TV can direst the sound to the proper port.
Sharp setup codes
Hello Michael
You are always better off starting your own questions rather than tagging to an existing one from January 2014. You question is lacking vital information which leads to us having to guess. Questions must always have FULL 'make model (what it is)'.
0066 is your codeSoundbars: Setup and Code List
BrandcodeSHARP0066
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
I hope this helps.
Top Sharp Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
