Question about Car Audio & Video
My audio power says turned off in my 2019 TLX Acura and the microphone has a line through it. It just stopped working. Was fine yesterday. How do I turn it back on please.
Posted by Adrienne Velardi on
Alphanso Tee
    New Friend:
  • 169 Answers
Is it a factory system
Posted on Jun 16, 2019
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Hi i have a DEH-9600P
sounds like the radio has just broken. try getting it warrentied
Posted on May 29, 2008
Anonymous
SOURCE: Audio fades then stops after a few minutes of power
I had this problem on a sharp flatscreen lcd. the audio output i.c. was a surface mount chip-had to change complete signal board assembly,
Posted on May 02, 2009
Anonymous
SOURCE: polaroid tlx-04240b loses picture
I'm very appreciate to jranada's solution, my tv gets new life.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Posted on Apr 27, 2010
Anonymous
SOURCE: my Acura 2003 TL 3.2 stop working all both system
it is probably the blower motor resistor, had the same problem on 2003 CL Type s, the fans for the A/C and heat just stopped working was the symptom . The part is only about 70 dollars.
Posted on May 21, 2010
Anonymous
SOURCE: internal microphone stopped working for T410 Lenovo
reinstall the driver and check if it works
Posted on Feb 17, 2012
The ignition key will not turn. Worked fine for 10 years and stopped yesterday.
CAR MAY HAVE FORGOTTEN KEY PROGRAMMING TO START THE VEHCILE. IT WILL STILL REMEMBER CERTAIN PERSONAL SETTINGS BUT IT WONT ALLOW THE VEHICLE TO START. TAKE TO YOUR NEAREST ACURA DEALER TO HAVE THEM RESET THE KEY PROGRAMMING.
Apr 09, 2013 | 1999 Acura 3.5RL
My At 4040 just stopped working, no sound ?
Use a volt meter to measure the phantom power. Measure DC voltage between pins 2 and 1 and then between 3 and 1. They should measure the same and be between 12-48 volts dc.
Dec 30, 2012 | Audio Technica Audio-Technica AT4040...
I have a nova microphone and have never been able to get it to work. when i hook another mic up to the line it works fine, but when i hook the nova up it does not register any sound.
Perhaps it is phantom powered check the specs it may need 48V DC power, most mixers have this built if not then you can ask a store for a suitable power supply.
Thanks for using FixYa
Jan 23, 2011 | M-Audio Nova Professional Microphone
Hi i am using the audio technica at2035 condensor mic and the m audio mobile pre 2nd gen. audio interface. yesterday the mic was working fine with no problems but today for some reason i have to really...
This mic has a 10db pad or attenuator switch near the bottom of the barrel... make sure you haven't accidentally engaged it.
If that's not.... it try changing the lead. Also the power supply on your preamp could be failing.
These are a few cheap things to try before spending money for fixing.
Nov 29, 2010 | Audio Technica AT2035 Professional...
Desktop Microphone 600 works on roommate's HP but not on my Dell
Be sure your microphone is working fine, try to reconfigure your sound device. maybe you've miss something
Jul 27, 2009 | Logitech (980240-0403) Microphone
My 1997 Acura 2.5 TL will not start
change out the full relay under the dash on the driver side
Jan 24, 2009 | 1997 Acura TL Series
Wont Turn over.
test your battery if it is fine then it is your altenater
Sep 25, 2008 | 2004 Acura RSX
Microphone distorted
is this a power mic? check with a back up mic if it does it with the backup its not them its past them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 01, 2008 | Audio Technica Audio-Technica AT4040...
Car Audio & Video Logo
100 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
