Question about Ricoh Office Equipment & Supplies
My ricoh mp3055 is showing replace fusing belt unit, beside the fusing belt is in good shape.There are no physical damage on the fuser belt....Any SP codes method to solve the problem...
Waleed Ibraheem
    Habit-Forming:
    New Friend:
  • 60 Answers
Do SP 7804 021
Posted on Apr 22, 2020
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: Ricoh SP C410DN error code SC306
Reaseat the cyan photo conductor
Posted on Feb 23, 2008
ricohguy
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
Joseph Micallef
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Joseph Micallef
  • 86 Answers
SOURCE: Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Posted on Jan 21, 2009
Anonymous
  • 4 Answers
SOURCE: Desperate!!! Ricoh AP3800C Error SC552 fixed last week now back
SC552 means that the pressure roller (Lower roller in the fusing unit located in the left hand door of the machine) is not warming up correctly. Is the copier installed somewhere cold? i.e. a garage? If conditions are ok and damp is not a problem, either the thermistor that controls the pressure temperature is defective, or the lamp that warms it up is defective. They are the two more common problems, might be worth looking for one on ebay. However they are approx 250 pounds so if you can find a second hand one thats cheap for spares I would recommend that. Email me if you have to do this and I will talk you through changing the parts.
Posted on May 14, 2009
Help need for getting rid of SC 544-00 on a Ricoh SP C830DN machine.
SC 544 is a fuser overheat error. This could be caused by power outage or fluctuation in the power.
go to service mode. Hold down both "home" and "simple screen" for about 5 sec. and then press "user tools"
once in service mode go to SP5810 reset fuser error.
and reboot the machine.
Feb 19, 2017 | Ricoh Aficio SP C830DN - Printer - color -...
C546
change the fusing unit completely and put on the machine.
if the error appears again, enter the sp mode by
1,press the yellow key say three times and enter keys 107
2,press and hold the stop/clear key for say 5 seconds .the machine will take you into the sp mode.
3,put of the machine for about aminute and put it on again .
I believe when you follow this step well ,thie problem will be solved
GOOD LUCK.
Jun 11, 2014 | Ricoh Aficio 2045e 2035e Copier...
Ink Fusing Issue
Replace fuser unit. Be sure you are setting the paper type when printing. Thicker paper requires more heat and will damage the fuser.
Nov 06, 2013 | Ricoh Aficio SP C410DN Laser Printer
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
How i reset maintenance on ricoh aficio sp 4310n
The machine will automatically reset the maintenance message when the fuser is replaced.
There is a looped wire on the fusing unit connector containing a thermo fuse (a thin wire that quicly melts, and then short the cirquit).
If you don't want to replace the fuser yet, you can probably set the machine to meter charge, SP mode 5930, and then reset the maintenance counter with SP mode 7804.
You can of course take out the fuser, and replace it with a dirt cheap thermo fuse bought from Ebay. Then set the fuser back into the printer, and it will clear the maintenance message automatically.
Either way should work fine, at least it used to do that on the previous model - and it is almost identical.
Dec 20, 2011 | Ricoh Aficio Office Equipment & Supplies
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Fusing belt damage
You should be able to buy the part from a Ricoh dealer - it's a part as opposed to a consumable. There are, however, two issues to take into account: 1) It costs nearly as much as a complete unit to buy 2) They are really tricky to fit.
I suspect you have used the old oil supply unit in your new fuser. If so the problem is probably there.
It may be that the paper jam has broken one of the upper fuser fingers. In the past I have removed these and the fuser has worked fine. You may find you get the occasional rap around but it should be a rare event.
Nov 21, 2007 | Ricoh Aficio AP3800C Laser Printer
157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
