Question about Russell Hobbs Irons
We have a Russell Hobbs steam iron,Model No.22191,doesn't produce steam anymore.We have replaced the anti-scale cartridge
Posted by John Davies on
5 Related Answers
smilemaker
Kanth raj
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
Anonymous
SOURCE: Russell Hobbs Steam Glide 2200 won't produce steam.
I had a problem and tracked it down to the pump. If you take the iron apart, the pump sits towards the front of the iron and has 3 tubes connected to it. Remove the srew-down bracket and free the pump from the plastic clasps on the base. Disconnect tubes and wires (remembering where they go.
Remove the circular securing spring from the front of the pump and drop the metal barrel from the housing. Unscrew the rear plastic assembly and set aside. there is a joint inside where the plastic assembly was - this is has an o-ring and is simply a pull-apart. It deos not need screwing. Pull the metal barrel apart, taking care to note the sequence for reassembly. Inside the barel is a larger rubber washer. Pull on the metal tube that goes through the centre of the washer using a pair of pliers - it will come free.
You will then see the problem - the spring inside the metal barrel will have broken. Take care, because at the other end of the spring is a small plastic washer that must be retained. Find a pen that has a short spring inside and use this as a replacement. If necessary, you can trim the spring to make it the right lenght. Ensure you have removed all broken pieces of spring, and reassemble. Try it out before finally attaching the pump inside the iron. It took me 2-3 attempts to get the spring tension right. If you can find a 'PENAC RB-085B BA1002' pen, the spring is perfect.
Once you have got it right, reassemble.
I have to replace the spring approx every 6 months as the replacement is obviously not meant for the job and wears or rusts or breaks. However, I am getting extended use from my otherwise broken iron.
Take care - things inside get HOT!!
Hope this helps.
Posted on Dec 17, 2008
Anonymous
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
Anonymous
SOURCE: Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Posted on Mar 24, 2009
Anonymous
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
My Iron heats up but no steam comes out and no noise please help !! Russell Hobbs steam 2200
If the water used is hard it will build up with shale, and block the steam vents, best to flush with clean water after every second use . Best to take to the dealer and have it serviced .
Jul 10, 2015 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
I am trying to find a replacement filter for the russell hobbs steam station Model RHTC102ST
where can i purchase a filter for Russell Hobbs steam station model rhtc102st
Mar 19, 2010 | Irons
Irons Logo
277 people viewed this question
Top Russell Hobbs Irons Experts
NOEL
NOEL
Harrie
john h
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
