I have also cleaned its lens but nothing happened.
Unfortunately the laser can die after only two or three uses. But most of these players have at least a year warranty. I recommend taking back to the place of purchase.
Testimonial: "Hi Mike, Actually this player had only 6 months warranty which has passed now. I have used CD or DVD only 2 times in it as I mostly used it through USB port using pen drive. I am wondering if this issue can be due to flex cable fault if flex cable has different lines to supply power for CD laser diode and DVD laser diode ?"
the cable, if it has the right ends on it allowing it to plug into the equipment correctly, will have the correct wiring configuration. But those cables can and do go bad on a regular basis. Power is through one pair of cables and data goes through another. There are multiple issues that can cause the reader to stop functioning. Try a CD and a DVD. If one works and the other doesn't oh, it is likely your laser reader. But to answer your follow-up oh, the cable can be the problem.
SOURCE: used lens laser lens cleaner & now player won't play.
Hi Mollins, did you ever resolved your DVD player issues. I have the same problem and I dont know what to do.
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
SOURCE: Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
