Question about Audiovox Televison & Video
SOURCE: Mitsubishi VS-55707 Rear Projection -
My brother had the same issue. I have the same set as well with this very issue. My brother had his fixed: repairman soldered the circuit board???? My brother could not tell me where on the circuit board or what circuit board???? IF there is anyone that knows about this....it would be helpful. I DO NOT WANT TO have someone else do what I can fix myself....besides by the time I pay a repairman I am 1/3 of the way or better to a new set anyway!!! Thanks a bunch - Pam
Posted on Jan 18, 2009
SOURCE: Mitsu WS 55711-Power up on panel or remote and
UNPLUG TAKE OFF BACK ,,CHECK THE FUSES,,
Posted on May 15, 2009
SOURCE: Audiovox D2016 returning to the beginning during playback
the player is not able to read your disk ...if the disk is clean and it does the same thing for other disks as well then you probably have dust or debree on the laser ... on some players you can see the laser .. it looks like a little lens thats very springy ...you can clean it with a soft tissue wetted with eye glass cleaning fluid .. dont spray directly on the laser ...gently clean the laser lens .... if you cant see the laser with the lid open then you can purchase a DVD/CD cleaning disk ... that looks like a regular DVD but has little brushes mounted on it to clean the laser when you play it ....cleaning the laser usually works but if it doesnt then you could have a damaged or worn out laser .....just a single hair or particle is enough to keep the laser from working...
Posted on Apr 12, 2010
