Question about Toshiba Gigabeat MET400 Digital Media Player
Toshiba Gigabeat doesn't work
I have this error message: Update or restore the gigabeat using PC application. Read User Manual. Model is MET400
    Sergeant:
  • 338 Answers
looks like the player is asking for a firmware update.perhaps u accidentally erased parts of it beforehand and now it is a bit on the blind side..
nevermind, get the latest firmware(gigabeat room 3.0) here:
http://www.toshiba.co.th/download/support.html
and find more info on the giga here:
http://en.wikipedia.org/wiki/Gigabeat
(choose the program fitting your windows version!)
for more support and FAQs visit
http://www.vistax64.com/vista-general/37343-toshiba-gigabeat-xp-compatible-w-vista.html>
good luck
Posted on Aug 08, 2009
Help
You require the restoration tool. Try this:
http://www.aibohack.com/giga/repair_gigabeat.zip
And read the instructions carefully.
Oct 18, 2008 | Toshiba gigabeat MES60VK Digital Media...
Help
Download the firmware recovery application from here: Gigabeat S firmware. Follow the instructions and you will be all set.
Help!!!
So, what happened when you connected the thing to sync with a PC and rightclicked on the tool-tray item for the Gigabeat?  Maybe you got a menu about Upload Portable Media Center?  If not, go into applications and see if the gigabeat stuff doesn't happen to contain the bespoken user manual.  Open it...read it....  Usually there's a little button-sequence to prepare the player and another to restore the Portable Media Center program.  Happy discovering.
Jun 16, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES30VW
i'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
May 26, 2008 | Toshiba Gigabeat S30 MP3 Player
Problem
does it have a 4 with a triagle around it? if it does its screwed
Mar 28, 2008 | Toshiba gigabeat S MP3 Player
S series, update or restore?
I had the same problem. Reinstalling the firmware solved it but you can't get it from Toshiba (they were no help). I found a copy on the web but have since had a hard drive so I no longer have the file. Try a Google search for gigabeat firmware and you should track it down.
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Portable Media Center error
Have you tried formatting the drive?
Dec 07, 2007 | Toshiba gigabeat S MP3 Player
I have a Gigabeat V30
when you swap the hard drives did you copy the software (not music) from the old to pc.......this is the software that is needed to be on the(that you would have paste to the 80) before your place any other files on it.............
Mar 05, 2007 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat MET400 Digital Media Player Logo
423 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
John Long Shipton
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
