Question about Freezers
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
SOURCE: I have a Zanussi chest freezer. What does the red
its too warm,could be iced up or worse.
Posted on Aug 12, 2010
SOURCE: I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
Posted on Oct 01, 2010
SOURCE: RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
Posted on Mar 29, 2011
SOURCE: Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Posted on Apr 30, 2014
Sep 21, 2018 | Freezers
Sep 14, 2018 | Freezers
Jun 26, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Apr 02, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Mar 05, 2014 | RCA FRF434 - Igloo 3.6 Cu Ft Chest Freezer
Jan 25, 2014 | Igloo Cooler Igloo - 6.9 Cu. Ft. Upright...
Oct 04, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Feb 16, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Sep 20, 2009 | Freezers
186 people viewed this question
