Question about Sharp Computers & Internet
Since this sharp unit does not have a jack, I want to plug in headphones to external soundbar/speakers - will this work?
Posted by robin f on
5 Related Answers
Brian Payton
  • 44 Answers
SOURCE: No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Posted on Sep 17, 2007
hi99ins
Tim Higgins
  • 123 Answers
SOURCE: External speakers won't work when plugged in to computer
Make sure the balance control in your VOLUME CONTROL icon in windows tray (by the clock) is centered....
There are sliders for each output/input and a balance control for each of these. uncentred they can switch off one channel.
Posted on Jan 08, 2009
Anonymous
  • 273 Answers
SOURCE: how do you connect external speakers. Which
use hte head phone output as the speakers have that jack plug
Posted on Jun 07, 2009
Anonymous
  • 5 Answers
SOURCE: speaker/headphone jack won't work
It may not be the problem of sound card,
try following:
1) try uninstalling/reinstalling the sound drivers from device manager.
2) put the laptop to sleep(standby) mode and than wake up.
Please visit http://www.fixya.com/support/t1728089-speakers_work_but_headphone_jack for more details..
Update, if the solutions work..
Posted on Jul 01, 2009
AYYASAMY KASIRAJAN
  • 523 Answers
SOURCE: Headphone jack not working
Hi Friend,
The problem is with your head phone it may not correctly connected,kindly check it out or replace with the other headphone and check it.
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Posted on Aug 02, 2009
Have a Suzuki Hp-110 digital d electric piano after plugging in headphone into jac external speaker nolonger works
IKf you are meaning the speakers don't work when the headphones are pkuged it, that's the way it's supposed to work. If you are meaning the after you plug in the headphones and then unplug them the speakers still don't work, that means you either have a dirty headphone jack or the jack itself is broken.
Jan 03, 2017 | Electric Music
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Headphone jack not working on dell d810
andys_cars,
You may need to go into the sound properties and then to deviceto change the settings to enable the speakers and change it from headphones to speakers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 04, 2013 | Dell Latitude D810 PC Notebook
I want to add Speakers, where to plug...
The jack when inserted is supposed to cut the main speakers off---the only suggestions I have would be:
Contact the MFR. customer service to see what options they can offer
Consider if the set has connections for external speakers to look for one you can put close to her---some of those units also have a jack for headphones that will not turn main speakers off--just the one in the external unit.
Mar 19, 2012 | Televison & Video
The external speakers attached to my m audio prokeys 88sx are no longer working. I have replaced the fuses in both but the fuses blow on power up. I then used the keyboard with a set of headphones. One of...
It is NOT likely the keyboard is "killing the speakers"... OR the headphones for that matter.
I suspect the problem is bad switch contacts in the headphone jack that cut off the speaker line outputs when headphones are plugged into the pro keys. These jacks are, to put it bluntly, JUNK... they are EASILY damaged by pulling the cable plugged into them sideways. You will need to service the unit.
Jan 16, 2011 | M-Audio Pro Keys 88 Premium Piano
How do you connect external speakers. Which
Jun 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
No sound from speakers.
Hi...
On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
Is there a MUTE switch on the unit?
Or an "External speaker off" thingy in the menu?
Sep 07, 2008 | JVC TH-M303 System
Adding Audio Output to TV
headphone jack is perfect. Buy ( radio shack, ebay,home depot,best buy ) the mini plug to rca breakout cable and once you plug it in it should mute speakers. Otherwise go into menu, audio, and usually there is a selection to cut off speakers
Dec 03, 2017 | Sharp 27J-S260 TV
Computers & Internet Logo
24 people viewed this question
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ngoro
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
