SOURCE: the brushes will not spin
Pull out the brush block, make sure it will turn and to see if the shaft is on it, the shaft goes up into the turbine. If the block is ok, then the turbine isn't working. You take it apart and clean out the turbine, or replace it.
SOURCE: brushes won't spin on the
Is this a Hoover? If so the turbine which drives the brush block is bad. If a Bissell, could be a belt or on some the brush motor went bad. Really need to know what you have to help you more.
SOURCE: The brushes wont spin on my Hoover rug shampooer
try cleaning brush...
if sam problem need replaced turbine part no:
43191009
Turbine & Gear Assem
SOURCE: the brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
