Freezer side get warm turn setting to colder then it get below zero.Could the defrost stays on too long?
XHi, it could be possible, you've got a defrost problem, possible faulty defrost heaters, defrost timer, or faulty thermodisc(defrost thermostat) if you think defrost stays on too long, then you can replace your thermodisc, first, remove screws and back panel in freezer compartment, where fan located, if you encounter excessive ice, take your time, give it little time to melt( thaw) out, check on evap coil, you will see a device round clip on to evap tub, connected by two wires, buy one and replace, also note it's always better to replace defrost timer and defrost thermostat at the same time, but before you do any repairs, you should unplug ref, remove all produce, clean and make sure all ice melted,after few hrs, plug it back on empty, let it work for about 50 mins then put back your produce, you could be experiencing moisture buildup, when days are hot, or when room temp are high, or when you used ref regularly, hot air gets inside and could cause excessive ice build up, that could make ref, malfunction, good luck.
Replace temp controll
