Question about Homelite Garden
I have a Homelite UT08932 Vac Attack 2 blower that needs a new primer bulb is there a replacement available that will fit without having to replace whole carburetor
Posted by JOHN CORSI on
Jim flowers
  • Homelite Master
  • 1,098 Answers
You should be able to replace the bulb. take the model numbers to any mower parts store and they can get you this part.
Posted on May 27, 2019
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
Anonymous
  • 437 Answers
SOURCE: does this blower use 2 cycle mix
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
Posted on Oct 12, 2009
Anonymous
  • 148 Answers
SOURCE: I need the proper gap for a new spark plug for my
Proper gap is .030 inch.
Hope this helps,
Dolf-
Posted on Oct 16, 2009
Testimonial: "got the proper gap from the homelite manual online (.025) thanks"
Anonymous
  • 3 Answers
SOURCE: primer bulb is cracked on my Homelite Blower/VAC
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Posted on Apr 30, 2010
SOURCE: I own a Homelite Vac Attack II Model UT08546. The
OK! You know if you put fuel in it runs. You have replaced the fuel lines and filter which is great too. What is left? Two things....
1) fuel inlet screen inside the carb.
2) diapragm lever arm clearance.
Both of these are under the little covers on the carb. The one with four screws is the diapragm. The other will have one or two screws which is the inlet screen side.
Remove the gas from the vac and proceed to take the fuel inlet cover off.
The cover is under the air filter body so you have to pull the two star head screws out to get to it. With the fuel inlet cover removed you can pick out the screen inside the round hole and check it for debris/gelled fuel. These things plug at the drop of a hat! You can either try to clean the screen or go to a parts store and pickup a fresh one. I would go with a new one since the screens are so delicate cleaning is almost impossible. If you hold the screen up and look through it you will understand what I mean. You can also look on Ebay and order one and get it by mail. Which might be easier and still cost effective.
Once you replace the screen *(you put in the new by setting it in the hole and gently pressing it in with something blunt and about the size of the hole. It wont take much effort so be gentle. Once the screen is in put it back together, add a little fuel, and check the primer for rebound.
That is to say that the primer , once pushed in, should come back out quickly and fill with fuel. If it drags or stays in you still have a block somewhere in the system. This might mean removing the carb and stripping it completely and cleaning all the passages.
Do the screen thing first and we can discuss the diapragm work after that. Here is a link to homelite too:
http://www.homelite.com/service_support/order_parts
Posted on Aug 06, 2010
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
How do I change the primer bulb in my homelite vac attack 2
Most primer bulbs have small metal ring holding them in place. If you are careful you can usually pry this ring out in one piece but when you purchase a new primer bulb they usually come with new ring and you don't have to be so careful getting it off. Good Luck...
Jul 19, 2011 | Garden
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
I have a Homelite VAC Attack II that dies when you increase the throttle after it has warmed up for about 5 minutes. Any ideas?
Sounds as if its running out of petrol to the carb,have you checked for dirt in the tank,and or carb,failing that,you may need a new carb kit ,diaphram etc,they are available on ebay,rgds
Sep 26, 2010 | Homelite Leaf Vac Attack
My Homelite Vac Attack II is 4 years old and I
fit new pump ad float diaphragms in the carby
the fuel mix has become irrelevant as Stihl have an oil that is a 50:1 oil and covers all ratios and mixtures
do not use any e-mix fuels as that destroys carby components
Aug 09, 2017 | Homelite Leaf Vac Attack
My primer bulb cracked, can I replace it?
Yes, in fact event he DIY centers have parts like that available off the shelf or ACE Hardware. You will need the specific model number to ensure you get the right part or bring the old part with you.
Jun 03, 2010 | Homelite Consumer Products Backpack...
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
Apr 24, 2010 | Garden
Blower will not prime and start
Primer bulb has hole in it or fuel line cracked.First use needle nose pliers to crimp fuel line just before primer ,dont use to much pressure and see if bulb will hold vacuum when you press it.If it wont hold vac either buld has hole or valve in primer is defective.If it does then you need to crimp off fuel line feeding carb and see if primer holds vac.If it does not then you need to replace powervalve inside carb.
Nov 16, 2009 | Homelite Garden
Garden Logo
85 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
