Question about Car Audio & Video
I have a 5 wire self lock function twist throttle. I need help connecting the wires to my controller
5 wire throttle: red-5v, white-output, black-neg., green-battery pos. yellow-switch
Posted by KaMeEkAzEe [gLoVeFx] on
5 Related Answers
Cerfer39
Greg Stokes
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
Anonymous
  • 1463 Answers
SOURCE: need help !!
have you tried there web site for the wireing instructions or manual to installing it.
Programmable thermostats at discount prices at
hunter-thermostats.com.
riz.
Posted on Feb 26, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
Anonymous
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
Anonymous
SOURCE: trying to hook up a dimmer switch it has a red
For a single-pole installation:
1. Connect the 2 white wires together (one from the source and the other to/from the light fixture) - 2 wires
2. Connect the black wire from the source to the black wire on the dimmer switch - 2 wires
3. Connect the black wire to/from the light fixture to the red wire on the dimmer switch - 2 wires
4. Connect the ground wires - 3 wires
Posted on Mar 30, 2009
Martec ceeling fan/light wiring diagram needed or step by step guide for connecting wires.it was a mess and all not workin so need to get sorted asap.someone help.
depends on how your ceiling box is wired. if your box has a black, white, or green or bare ground you need to twist your blue and black wires together and connect to the black wire in the box connect white to white and green to the green/bare wire. if you have a three wire connection (black,red,white,green/bare) you connect red to blue black to black white to white and green to green/bare
Apr 05, 2012 | Home
Im trying to install a Utilitech 0192773 self adjusting wall timer. It has four wires, black(hot), red(hot), white(neutral) and green(ground). I have a standard three light switch plate(outside light,entry...
Thank you for clear description of wiring, switches, and for including timer model number.
1) Open following link for ez programming and wiring for Utilitec.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
2) Your single-pole switch has 2 wires.
0192773 replaces single-pole switch only.
Black wire that connects each of the switches is Hot wire: connect this wire to timer Black wire.
Other black wire that connects to switch goes to load: connect this wire to timer red wire.
Timer white wire connects to white wires that are covered with wire nut.
Timer green connects to bare ground wire.
3) How to connect stranded wire and solid wire
http://waterheatertimer.org/How-to-twist-electric-wire.html#stranded
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Intermatic & Self-Adjusting Wall Switch...
Had to change tower looking for the layout to connect the front usb wiring to the board , need to know which wires go on the board
motherboard usually red-white-green-black
Standard USB Cable Wiring Color Code
5V / Red
D+ / Green
D - / White
Ground / Black
hope this helps
Mar 31, 2011 | Intel Motherboard
What are the electrical readings on the throttle positioning sensor
The throttle position sensor has both an idle contact switch and a basic 3 wire potentiometer that measures throttle angle opening. The idle switch and the throttle potentiometer share a ground wire.
To test the sensor first you have to verify that the wiring is intact by
1. Disconect the sensor and with a volt meter check the 4 wires. I have attached a wire diagram and picture of the pin layout to make it easy for you.
Pin 1 ( Yellow wire) is the PCM reference voltage. Specification is 5V
Pin 2 ( Red and Green wire) is the signal wire for the TPS. Specification is 5V
Pin 3 (Blue and white wire) is the idle switch. Specification 5V. Please note that this circuit is not actually used by this year Sedona so some vehicles are missing the wire.
Pin 4 (Black and yellow wire) is the ground. Specification: continuity to ground ( less than 1 ohm)
If the voltages are correct next you want to check the sensor.
1. Connect the throttle sensor connector.
2. Key on engine off
3.With a voltmeter measure terminal 2 of the sensor with the throttle closed, Specification is .2 to.4 volts.
4. With ta voltmeter monitor terminal 2 with the throttle fully open.The specification on terminal 2 is 4 to 4.4 V.
5. Slowly open and close the throttle while monitoring terminal 2 and make sure you have a smoot increase and decrease in voltage as the throttle is moved from close to open throttle and returned to idle.
Jan 12, 2011 | 2005 Kia Sedona
I am trying to wire a timer switch in a four gang outlet box and the timer switchhas a red, black, white, and green wire. The existing switches in the box are all wired with two black wires and one copper...
Your switch has two black wires.
One of these wires goes to Load (light fan motor)
The other wire is hot. And this wire probably connects back to other switches in box making it easy to identify.
Timer-black wire goes to hot wire.
Timer-red wire goes to Load wire.
Timer green wire goes to bare ground wire.
Timer white wire runs the clock located inside timer. So timer clock is just like alarm clock, and needs its own power.
In back of 4-gang box are white wires that are twisted together and covered with wire nut.
These are neutral wires.
Timer-white wire connects to neutrals, and this completes clock circuit.
Dec 07, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
I have an outside spot light with a motion detector controlled by an inside switch. I want to change outside fixture & install dimmer switch in place of wall switch. I removed outside fixture. There...
First, let me say that if you're not entirely comfortable doing high voltage electrical work, you might want to call an electrician. It's not impossible for you to get hurt or killed or burn down your house. At least be sure to turn of the circuit breaker while you're working on it.
The blacks and whites twisted together are passing through power to other parts of your premises and are always on, so be sure to keep them twisted together. The red is the one that will take power from your light switch and send it to your light fixture.
At the fixture, connect the white to white and red to black, the same as before. At the light switch, connect the black to one side of the switch and the red to the other. When you turn on the switch, it will permit power from the black to travel down the red to the fixture, and from the fixture, the circuit will be completed through the white.
Sep 12, 2009 | Leviton (102-5G108-RW5)
Photoelectric Control (Photo Eye), dawn to dusk, install
Connectthe SUPPLY wire (Black) to the Photoelectric Black. ALL of the white wires - to lights and from supply and on PE - connect together
Redfrom PE goes to all light fixture black lines
Nov 24, 2008 | Electrical Supplies
Car Audio & Video Logo
101 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
