Question about Water Water Heaters
Easy flow afs102 water does not get thru to base unit. the unit before the heater part no jyc-2 have a valve to allow water thru
Posted by bob rowlands on
ray gallant
    Top Expert:
  • Water Master
  • 68,551 Answers
CALL YOUR LOCAL PLUMBER AND PAY TO HAVE THEM FIX IT
Posted on May 02, 2020
5 Related Answers
Fahr Quad
  • 774 Answers
SOURCE: my ranai tankless heater is not working
Check the electrical supply to the unit but my guess would be an issue with the water flow sensor.
Posted on Mar 16, 2009
Anonymous
  • 244 Answers
SOURCE: model PTG-42PVN
According to the symtoms...sounds like you have a problem with the flow control valve. If less than 3 yrs old, contact Rheem Customer Support at (800-432-8373) and they can an authorized tech in your area to service the unit.
If the unit is out of warranty, I reccommend you still call customer support to find a local technician. Unless you're highly technical/mechanical, this is not a problem you should attempt yourself.
Thanks for trying Fixya.com
Mike...
Posted on Feb 07, 2010
Anonymous
  • 332 Answers
SOURCE: My rv water heater ignites, I have a steady flow
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
Posted on Mar 06, 2010
senor8
Chris Sellers
  • 73 Answers
SOURCE: noritz tank less propane water heater, no out going pressure
There's a filter on the cold water side of the unit. You'll notice a black, plastic, cylindrical component directly below the unit on the cold water line pointing to the left. If you shut of your water and unscrew that cap, there will be a filter attached to the other end.
If the filter is clean, I'd recommend calling tech support for help. You might have an error code.
Posted on Aug 01, 2010
Gene Haynes
  • 5391 Answers
SOURCE: Have been running extremely hard water thru our Noritz NR98-DVC for a couple of years. Unit is not functioning properly. What, if any, damage could result from using this hard water? Could there be
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To possibly solve problem temporarily, install softening system, delime tankless unit using white vinegar. Delime yearly. It is fun for whole family. And who doesn't like a project schedule.
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Oct 12, 2012
My water heater makes a loud bubbling sound for a few minutes after I run hot water for a while. Is there something I should do for this? If so, what and how? Thanks.
The horrible noise you hear when the water heater fires up is probably caused by mineral buildup in the bottom of the tank. Hot water rises and flows by convection to the top of the tank. When you take a shower or turn on the dishwasher, the hot water you use is replaced by cold water that migrates to the bottom of the tank to be heated.
As far as the fix, regular maintenance is the key. The best thing a homeowner can do is to flush the water heater on a monthly basis. This simple process involves hooking up a garden hose to the drain valve at the base of the heater, opening the valve and with the water inlet valve open to maintain the pressure in the tank, allowing the water to flow until the water runs clean. Try this first. It may help. If not, de-liming is the other option.
Mar 02, 2015 | Water Water Heaters
Water dripping from bosch water wizard 13b unit
you can rebuild the flow control valve to prevent this.there is also a new flow control valve that has supersceded some of the older ones.
Mar 15, 2013 | Bosch & Tankless LP Hot Water Heater
I have a propane hot water tank that in discharging the hot water out the relief valve (Champion energy saver series)
possible problems not knowing age of unit the
control valve could be sticking open allowing gas to continue to flow until high limit is reached and shuts down valve another possible problem with the newer style back flow preventer being install by water companys the rapid heating and expansion of the water over pressures the water system causing releif valve to pop open and reclose most water heater manufacters are recommending instalation of an expansion tank to allow the growth in volume of water somewhere to go is valve constantly leaking or only during heating cycle if you could supply additional information does unit only leak when heating
or is steam expelled when releif valve opens
t-stat not opening gas valve sticking partially open
bad high limit bad pressure releif valve no expansion tank to allow for thermal expansion if steam is present and unit is boiling water inside replacement of water heater for safety concerns,would be reccomended if only water and pops couple of times water temp not over 140 degrees after most hot water has been used out of tank and is reheating most of capacity probably lack of expansion tank as the releif valve is the final safety device on a water heater is of great concern
the temp control gas valve or high limit are supposed to shut unit done long before the safety limit of releif valve is reached
Dec 11, 2009 | Water Heaters
Seems it doesnt come on unless i turn on two
This is a common problem. They are desighned to come on when a certain volume of water goes through it and with todays low flow water conserving devises they don't always come on with one faucette.
You can have a loop installed that allows a higher volume of water to flow when a valve is turned on. It simply flows back into the supply side of the unit.
Aug 24, 2009 | Bosch AE125 PowerStar 4 GPM Indoor...
New Danby dishwasher - no water flowing into it
it sounds like the shut off valve has failed and not letting water into the unit, change the valve and it should work, even if it turns like it is working doesn't mean the washer isn't stuck keeping water from comming thru
May 26, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
High flow, unit gives up, bypasses cold water. Fault 10
what is the number on the unit and how many other faucets are running at the same time, dish washer, other showers, anything, the only other thing is that your unit could be undersized or the gas flow is not been properly set for the unit, not enough gas to the unit will let the water go thru but it won't keep it;s temp. how long have you had the unit, has it been flushed out lately? and if it's just the valves that you are showing in the picture, there are screens inside of them that might need to be taken out and cleaned there are 2 screens one on each valve, they have caps on them take off the caps make sure water is off at the valves clean off the screens and put them back in
Apr 29, 2009 | Rinnai Webstone The isolator EXP tankless...
My ranai tankless heater is not working
Mar 16, 2009 | Rinnai Water Heaters
Frozen tubing in heat exchanger
The 2400ES in cold climates needs to be a twin piped unit. 3" SS venting with a combination air port made of pvc also 3 feet apart I believe on the same wall and at the same plane. Keep the cover on at all times and this will seal of the heater from the rest of the house and from freezing.
Jan 13, 2009 | Bosch AquaStar 2400ES-NG
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Water Heater Replacement
1) After shutting off the water and gas or power supply to the tank, connect a hose to the drain valve at the bottom of the tank, open the valve, and run it to a nearby drain or outdoors. Use two wrenches to unscrew the inlet and outlet fittings from the top of the tank. 2) For a gas water heater, shut off the gas inlet valve and use two wrenches to disconnect the union or flare fitting between the gas supply pipe and the inlet valve. Also remove the flue hat that expels gasses into the flue at the top of the tank. 3) After removing the old unit, set the new one in place with the controls and burner accessible. Allow at least 6 inches of clearance around its perimeter, and keep it away from flammable materials. Use a level to check it for plumb; shim the base with pieces of asphalt shingles or plastic wedges. 4) Wrap the threads of the heat trap fittings with pipe-wrap tape, and screw the fittings into the water heater (blue into the cold water inlet and red into the hotwater outlet). Be sure the arrows marked on the fittings point in the direction of water flow. 5) Install new flexible connectors on the water inlet and outlet pipes. If there is no shutoff valve on the cold water side, install one before connecting the water heater. After all connections are complete, open the shutoff valve to fill the tank. While it is filling, open several hot water faucets in the house to bleed off air in the pipes. 6) Assemble the gas pipes as shown. Spread pipe dope on the threads, and screw together the parts, tightening them with one pipe wrench on the pipe and another on the fitting. Follow the manufacturer's instructions for connecting the unit with gas supply tubing. After turning on the gas, test all connections by brushing soapy water on them and watching for bubbles.
Aug 27, 2008 | Stiebel Eltron Tankless Water Heater
Water Heaters Logo
131 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
