Question about Car Audio & Video
White red black on ignition on harley big twin
Coil has two neg pos in the center
Posted by Rick Hotta on
5 Related Answers
zzedly
Tygh Duval
  • 300 Answers
SOURCE: dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Posted on Mar 17, 2008
Richie_asg1
Richard Perkins
  • 1036 Answers
SOURCE: c.b.radio-power won't come on.(red & black wire show short!)
The fault is probably at either end. Yes, it could have been reversed, but most radios are easily protected against this.
If you are getting no lights or anything when keying mic, then there may be an inline fuse along the cable. As you are getting continuity, open the case up, and look for any evidence of heat at the components nearest the power supply - particularly the protection diodes - Black cylinrical components with a silver band.
You really need a meter or scope to go in much further, and check supply voltages between components and -ve, and downloading a copy of the circuit diagram will help this.
The other main fault is usually the output power transistor - which needs a sink for all the power getting thrown at it. If you remove the antenna, it can quickly overheat and fail.
Both components can be checked in-situ for voltage (or not) but the output can only be tested with a scope.
Of course - the "on" light could have blown, so may be functioning without indications, - but I doubt it.
Also check Mic outputs on the plug to make sure that is working. Some units won't function if this is disconnected.
Posted on Jan 08, 2009
Anonymous
  • 16 Answers
SOURCE: harley davidson big twin ignition wiring
On Dyna S DS6-1 Dual Fire Ignition Systems
The WHITE WIRE connects to the POSITIVE (+) side of the coil
The BLUE WIRE connects to the NEGATIVE (-) side of the coil
Posted on May 01, 2009
CorvetteKing
Vacuum Medic
  • 108 Answers
SOURCE: Minn Kota 54lb hooked up backwards (Pos. to Neg) wont work
Unfortunately, those units have a circut board at the power source and if there is no fuse you more than likely destroyed that board. Take the casing apart (the part attached to the boat) it should be two halves. That inital board you see is probably what is destroyed. Of course before i did that I would look for an inline fuse near where the cables attach to the battery or under the unit in the nose of the boat. There is nearly always a fuse if it came from the factory or dealership with the unit so i'd play a little extra hide and go seek for that before doing anything else.
Best of Luck
Posted on Jun 05, 2009
WonderTech
WonderTech
  • 268 Answers
SOURCE: need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
Posted on Sep 22, 2009
What colors are the Speaker Wired for a 1993 gmc 1500 van
    1. OK,GMC/GM are wired as such. White/Black wire, front left -[neg] White, front left +[pos]. Grey/Black wire, front rt -[neg], Grey wire, front rt +[pos]....Green/Black wire, left rear [neg], Green, left rear [pos]....Violet/,Black , Rt rear [neg],...Violet, Rt.rear [pos]........You will also have a Blue/Red wire that goes to antenna. ..A Blue wire for Power Remote....Red goes to IGNITION.....Yellow goes to Battery[for clock].....And finally a Black goes to Ground.......I hope that you have good luck and everything works out for you. `
Sep 07, 2015 | GMC Cars & Trucks
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
How to wire in my tachometre on my mgb gt 1972
your tacho should have 4 wires 1 black =ground 2 green=ignition 3 white/black =ignition coil contact breaker side 4 red=illumination make sur your tacho is for the correct system ie. pos or neg ground
Oct 23, 2012 | MG B Cars & Trucks
Need color code for kenwood kdc mp 245
black - ground, red - switched or ignition, yellow - constant (memory) power, white - left front spkr pos., white/black - left front spkr neg., gray - right front spkr pos., gray/black right spkr front neg., purple - right rear spkr pos., purple/black - right rear spkr neg., green - left rear spkr pos., green/black - left rear spkr neg, blue - antenna remote, blue/white amp remote turn on.
Nov 02, 2010 | Kenwood KDC-325 CD Player
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
I cant figure out the rear speaker color codes on my 1996 pioneer deh-p725 car cd player, could someone help me?
red---------ignition
orange----constant
black------ground
blue--------remote
green------drvrs front
grn/black--drivrs front neg
grn/red------drivers rear pos
blk/grn-------drivers rear neg
grey pass front pos
grey/blk---pass front neg
grey/red---pass rear pos
blk/grey---pass rear neg
Gary
Jan 25, 2009 | Car Audio & Video
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Harley davidson big twin ignition wiring
Sep 01, 2008 | 1996 Chevrolet Caprice Classic
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
