Question about LG Televison & Video
I have an LG 60pv250, and the screen all of the sudden went black. I can hear it power on and off, and it has volume, but zero picture.. Any ideas?
Posted by Skeeter Parks on
b1jqxk44
    Habit-Forming:
    New Friend:
  • 157 Answers
The x or y sustain board died on you. It will be cheaper to buy a new TV and get rid of that plasma TV.
Posted on May 27, 2019
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
Anonymous
SOURCE: Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
Posted on Jun 01, 2009
gamefixer
Stephen Frye
  • 6 Answers
SOURCE: My MsPacman/Galaga upright has power but screen is black(blank)
I'm assuming this game cabinet was built in the 80's. More than likely, the monitor is an Electrohome GO-7. If this is the case, replace capacitor C511 on the monitor board. It has baked open due to old age. Usually, capacitor kits can be purchased for around 10 bucks, so you might want to replace all the caps on the board at ths time. Worst case scenario would be that the Flyback transformer has smoked (usually you'll see a crack on the side of the transformer), causing the horizontal output transistor to cook and also the smaller of the two pigtail fuses to blow. In this case, you would have to replace the Flyback transformer, the horizontal output transistor, and the small pigtail fuse associated with it. Remember to always discharge the second anode( the suction cup thingy on the side of the tube). It will hold a substantial charge on it. Also, if the small pigtail fuse is blown, you will need to discharge the large cap on the monitor board, or else it will knock you on your rear-end when you try to replace the blown fuse. Hopefully, you'll will only have to replace one cap. C511. If your game does not have an electrohome monitor, I can still help, if you provide the manufacturers info, such as Well Gardner model 7204, or something like that. Good luck!
Posted on Aug 16, 2009
David Low
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Posted on Jul 23, 2010
LG X Power cell phone. I was using it, it suddenly froze...wouldn't restart or respond to any touch screen requests! Then the screen went blank/black and still won't restart! HELP!!!
Have you tried holding down the power and volume down buttons simultaneously to do a reset? It normally takes 10-12 seconds before it reboots. The LG logo should appear, then release the buttons. The Power X has battery connection issues and will do random shut downs as well. If it's shown other symptoms like charging problems you will need to take it in for repairs.
Oct 02, 2018 | LG Cell Phones
How to repair a tv LG plasma 60pv250
Sounds like your Power supply is still good. but maybe the board for the video is bad.. (maybe the main board other than power supply. If you do a search on the internet for "60pv250" and "board". you can find replacement parts. If you are capable or know someone with some electronics skills you should be able to see if any parts on the existing boards are popped (sounds like a capacitor went) and then buy the right board
Feb 03, 2016 | LG Televison & Video
How do i fix my LG 50PC3D all of a sudden it has a grainy flashing screen and i hear the static through the speakers so it has sound.
Contact the authorized service cener for LG; in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 23, 2014 | LG Televison & Video
What are the best picture settings for my lg 60pv250?
http://www.avsforum.com/avs-vb/showthread.php?t=1346417
try these settings, or just mess/tinker with it until you find one that is the best. But, search AVSforum.com for LG 60PV250 and you will probably find something that is helpful.
Dec 26, 2011 | LG Televison & Video
While checking Vscan voltages on my LG du-42px12x picture died.
I have the same problem the pic went out but have sound. where do i go to get the Yboard? do i need a special number off of it or something? I took it to repair shop and he said it would be like 500 dollarss to repair. but i see all kind of yboards on ebay for like 150?? how do I know what one to buy?
Mar 15, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Vizio GV47L screen went black and is now unresponsive
Could be the power supply gone bad.
No easy solution I'm afraid.
May 20, 2009 | LG 47LC7DF 47 in. LCD HDTV
42px5d got sound but no picture
You need the Y sustain and y drive boards. No idea where to purchase in australia, but you may be able to order them from LG.
Jun 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
59 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
