Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Appreciate your help! My Bose ipod docking station just makes a clicking sound all the time and will not work. I have tried the plug both ways and it is the same. dean
Posted by deanward896 on
Anonymous
  • 73 Answers
This device seems to have a lot of problems with power - I'd suggest calling Bose. They are no doubt well aware of the problems with them and see if they will replace it.
Posted on Aug 07, 2009
My bose docking station is making a loud knocking sound when I put the ipod in it.
You have it plugged in, incorrectly! You need to look and find the symbol that is on the plug end and match it with the symbol on the back of sound dock. As time goes by the plug can get a little worn down allowing it to be plugged in, in any orientation, thus causing the knocking sound that you hear, that should fix the problem, enjoy!
Sep 29, 2012 | Bose SoundDock® (Black) Docking Station...
New ipod won't charge on bose docking station
I have been looking for sometime and have finally found a 3rd party power converter. Another solution is to send your docking station to Bose and for $99.00 they will repin the dock so charging will work. The converter and adapter only cost about $30.00. Here is the link to the site I ordered from. I just ordered it so I am not abot to confirm functionality yet.....
http://www.griffintechnology.com/products/firewire-to-usb-converter
Jul 25, 2009 | Bose SoundDock digital music system...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Mar 29, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
Gen 3 nano and bose docking station
Have you tried another iPod on it?? I suspect that if you do, that one won't work either. If it's a Bose SoundDock then they are well known for having problems with the iPod connector getting loose. Try with another iPod. If results are the same, take your SoundDock back. Bose should exchange it straight away.
Aug 06, 2008 | Apple iPod nano 3rd Generation
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
251 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
