I have a Toshiba 32LF221U19 TV that I'm only using a TV antenna. In the channel guide, it says program info current unavailable. The date and time are wrong. How to change date and time settings.
The correct time zone is selected, but date and time are wrong. I'm guessing this is why I can't get program info. Correct?
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Posted on Apr 25, 2008
Jason Morris
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 13, 2009
Muggs01
Muggs01
  • 72 Answers
SOURCE: Laptop date and time setting get disturbed automatically
do you plug into a network with a server if so set the computer to not change time to server time.
Posted on Jan 16, 2009
Anonymous
SOURCE: won't allow manual clock set - tv guide not loading
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
will self check, say test L1, power off, on again.. go thru setup. no data was lost.
Posted on Apr 06, 2009
rgladney
  • 5 Answers
SOURCE: product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at [email protected]
Good Luck!
Posted on Apr 08, 2009
Is there a TV Guide for the ematic AT 103B digital converter box?
There is an electronic program guide. However, it's limited. To see the current program and upcoming programs for the current channel, press the EPG button on the original Ematic AT103B remote. (Universal remotes may or may not match the function.) To see the other channel's program list, use the left/right arrows to scroll through the lists for all of the available channels.
You may find a web site like Titan TV, http://www.titantv.com/ , more useful. The site has a guide to all channels at once by time for your area OTA channels.
I hope this helps.
Jul 29, 2018 | Televison & Video
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
How do I program my Toshiba 40RU525R TV to set up channels using an antenna.?
Use remote to open menu. Go to setup. select antenna and auto program.
Jun 08, 2011 | Toshiba 47ZV650U TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Everything on the TV works EXCEPT live TV.
Please clarify a few things. Are you using cable TV, satellite TV or a TV antenna? If cable, are you using a set top box (and is it powered on) or does the TV convert the cable info. If satellite, is the set top box powered on? If off the air (antenna TV), can the TV receive the new digital signals and if not, do you have a digital converter box between the antenna and the TV?
Jun 04, 2009 | Toshiba REGZA 47HL167 TV
TV Guide System not working
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
Jan 24, 2009 | Pioneer PDP-5060HD 50 in. Plasma...
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
