Question about LG Televison & Video
My LG 55G2 comes on with picture and sound, then the picture goes off. The sound stays on, turning it off and on again brings the picture back for a couple of minutes. Can you help?
Posted by Joe on
b1jqxk44
    Habit-Forming:
    New Friend:
  • 157 Answers
You most likely have a week capacitor on the power board. When the TV warms up the cap stops working. Check for bulged or leaking caps and replace them.
Posted on May 27, 2019
5 Related Answers
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Posted on Apr 07, 2009
jjfierogt
  • 136 Answers
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Posted on Aug 08, 2009
Anonymous
  • 556 Answers
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
maatmartin7
matt martin
  • 1258 Answers
SOURCE: 47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Posted on Nov 23, 2009
Chi Chu
  • 8457 Answers
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
I have a lg moel 50pk750 turn on works great,then sounds stays on, no picture. turn off and five minutes turn on everything works good again,then picture goes off,
There is a circuit board going bad on it. You can get more detailed info on you tube. Just list your tv model and number and it will show you related videos.
Dec 15, 2017 | LG Televison & Video
LG 55LS4500, after turning on the TV the picture goes out after a while but the sound stays on. Wait a few seconds and turn it back on and the picture will come on again but after a while goes out.
BUENAS SERIA BUENO Q REVISARA EL CIRCUITO DE ILUMINACI?N DELA PANTALLA DE TU TV EMPIEZA POR AH? PARECE SER UN PROBLEMA DE SOBRECALENTAMIENTO SI TU TV ES PLASMA YO TU IRIA A POR LOS IC QUE ALIMENTAN LA PANTALLA DE NO SER ASI POR Q EL TV ES DE LED O LCD REVISARIA LAN LAMPARAS Y EL INVERTER EN ESE ORDEN ESPERO Q DES MAS DETALLES PARA AYUDARTE MAS SUERTE
Dec 11, 2016 | LG 55LS4500 55 in. TV
Reset LG 55G2 to factory settings
How to update my LG 55g2
Dec 28, 2013 | LG 55G2
Picture on tv goes black after 10 mins, the sound still stays on but no pic. then if left turned off for while picture will turn back on but on;ly for 10 mins again
What you described here is a issue with the LCD back light or one of the inverter boards going out on you. These boards can be found www.partstore.com or www.shopjimmy.com
From what you described this is basically what I come up with, if you update me with a serial number/ model number we could get you the part number and price.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 13, 2011 | LG RU-27LZ50C 27 in. HD-Ready LCD...
Sound stays on, but no picture- goes black and stays that way.
This unit should still be under warranty and should be taken in for warranty service. Any attempt to access the interior will void the warranty. It is important that a complete description of the problem like you entered here be taken along when you bring the set in for service. This will insure that the servicer be able to reproduce the problem and resolve it.
From your description (and as a servicer), I would be looking for a component that is heat sensitive. These types of problems are fairly easy to locate and resolve.
Please take this in for warranty service and update this when you find out the details.
Thanks,
Dan
May 04, 2010 | JVC LT-26C31 26 in. LCD Television
Sparkling on LG flatpanel tv
ok, phoned a technician today and he has diagnosed the y/suss board as gone and 150 to fix but cant guarantee it will fix it for good, another board may go pop z/suss . so its the local refuse collection point for it.
Jan 02, 2010 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Aug 08, 2009 | LG 47LC7DF 47 in. LCD HDTV
LG Flat Screen Problem
since when have you experienced the problem? does the tv still turn on or not...?
Aug 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Televison & Video Logo
82 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
