Tv plasma is fuzzy wehn you turn it on it has a good pic of a bit then goes fuzzy after a bit
Posted by John Welsh on
  • 1 more comment
  • John Welsh
    John Welsh May 31, 2019
    thanks how do you tell wich one
  • b1jqxk44
    b1jqxk44 May 31, 2019
    If the fuzzy lines go up and down that's the Y board and side too side it's the X board.
  • John Welsh
    John Welsh Jun 01, 2019
    It all over the scree
b1jqxk44
    Habit-Forming:
    New Friend:
  • Televison & ... Expert
  • 157 Answers
The x or y sustain board is on it's way out.
Posted on May 27, 2019
4 Related Answers
Anonymous
  • 1139 Answers
SOURCE: Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Posted on Sep 12, 2007
Anonymous
  • 114 Answers
SOURCE: my 42''
My Friend it all depends of what type of TV you have?
DLP? -----DMD board
LCD?----- Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Digital Video
PLASMA?-------
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} X sust. Board or Y sust. Board
Posted on Feb 10, 2010
gopakumarg43
  • 76352 Answers
SOURCE: my fujitsu plasma picture goes blurred and fuzzy after been on a while
Any one among the sustain drive board can be faulty. Contact any service technician and make it confirm. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Dec 01, 2013
gopakumarg43
  • 76352 Answers
SOURCE: My Norcent 4246 HD plasma TV picture is all fuzzy
Voltage problem. Check its Vs & Va voltages to panel. Contact any service technician. If any of these voltages is go beyond its limit, this kind of fault can occur. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Posted on Jul 08, 2014
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
My fujitsu plasma picture goes blurred and fuzzy after been on a while
Dec 01, 2013 | Fujitsu Plasmavision 42" TV
Hp pl5060n
It sounds like a panel fault. Anyway, check this link. It has details with illustrations to Plasma display panels. Check them to that of your TVs, and make sure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timslide option.
Jun 29, 2013 | Televison & Video
My 42'' avol tv goes fuzzy for about a minute then pics up a good picture. It does this inconsistantly but from time to time.
DLP? -----DMD board
PLASMA?-------
Feb 10, 2010 | Televison & Video
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
[email protected]
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Video appears distorted--halo like
check your sharpness setting, it should be very low and even in the negatives possibly on a plasma. I was told the sharpness option was for crt tube tv's anyway
Jan 05, 2008 | Panasonic TH-50PX75U Plasma HDTV
Sep 12, 2007 | Dell W4201C 42 in. Plasma HDTV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
