Vacuums Logo
Question about Bissell Vacuums
How do I take the hose off in order to replace it
I have a bissell model 35k3. I want to replace the hose on it. How do I take the hose off in order to put the new one on?
Posted by Dewight Farra on
Why is my Bissell ProHeat x2 revolution throwing water out the bottom rear of the machine?
Question edited for clarity and what I think you meant to say.
Question moved from Washing Machines to Bissell ProHeat.
When you drop the hose into a bucket of plain water the force on the hoses is like dropping 2 gallons of water in a pail on you head from 3 feet high. You have either had a hose connection disconnect, or a hose that has split.
Bissell ProHeat come in about 12 different models, so it is not possible to help you further. All questions need 'make model (what it is)'.
The Google Search Query is
make model parts diagram
to see a breakdown of how the parts connect.
https://www.google.com/search?q=bissell+proheat+parts+diagram
or 'make model manual', for Bissell's strip down information.
https://www.google.com/search?q=bissell+proheat+model+1699+manual
tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Replacing hose on a little green
Call the Bissell Consumer Care at 1-800-237-7691 they should have a cheat sheet to guide you through it.
What's your problem? how to replace nozzel for bissell quicksteamer
The User Guide for your Bissell 1770 QuickSteamer can be found here:
http://canada.bissell.com/images/UserGuides/1970-2080_English.pdf
Available replacement parts may be ordered online here:
http://canada.bissell.com/Products/p/1770+quicksteamer/ak/replacementparts/Product.aspx
Was not sure if you meant you were having difficulty with actually removing and replacing the nozzle? Please reply if you need further asistance
5helpful
2answers
The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
1helpful
Need pics of bissel hose assembly
Just what the doctor ordered:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This is not my website, you should thank the guy that made this. It took me a few days of searching to find it.
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
Replacement wheel
The rear number is 2036627, there is no side casing, you would have to replace the whole back, which Bissell isn't making avaiable. But o get the wheel, you might try bissell.com and see if you can order direct, or try a local repair shop to see if they will order it for you.
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
