Question about Samsung Televison & Video
I own a Samsung TV Model # UN60J6200AFXZA, no back lighting. Black screen but sound does come through. With the "flashlight" test i can see picture. What can be my problem? willing to fix it myself.
Posted by Carrie Villarreal on
Franco Dosil
    Top Expert:
  • Samsung Master
  • 10,535 Answers
Hello Carrie, so you comment, the problem is actually in the back lighting of the LCD panel
Usually the fault occurs because one or more of the backlight LEDs are burned and as they are connected in series circuit, the rest of the LEDs are turned off
The solution would be to replace the damaged LEDs, I suggest you get the new LED strips and replace all the LEDs, because if you only replace the burned ones, surely there are others that work, but they are already exhausted and soon would burn and that would cause you to have to disassemble the TV again
Be very careful with the handling of the LCD panel,
When you have to remove it, do it with another person who helps you, is delicate and could be damaged
I pass the link of a video about the repair of the backlight of a Samsung 50 ", the procedure is the same for your Samsung 60"
I hope you can solve the problem, comment the results, good luck
Greetings Franco Dosil
Hola Carrie, por lo que comentas, el problema, efectivamente esta en la iluminaci?n trasera del panel LCD
Por lo general la falla ocurre porque uno o mas LED del la retroiluminacion se queman y como est?n conectados en circuito serie, se apaga el resto de los LED
La soluci?n seria, reemplazar los LED da?ados, yo te sugiero que consigas las tiras de LED nuevas y reemplaces la totalidad de los LED, ya que si solo reemplazas los quemados, seguramente hay otros que funcionan, pero ya est?n agotados y al poco tiempo se quemar?an y eso har?a que tengas que nuevamente desarmar el televisor
Ten Mucha precauci?n con el manejo del panel LCD,
cuando tengas que retirarlo, hazlo con otra persona que te ayude, es delicado y podr?a romperse
Te paso el link de un v?deo sobre la reparaci?n de la retroiluminacion de un Samsung 50", el procedimiento es igual para tu Samsung 60"
Espero que puedas resolver el problema, comenta los resultados, buena suerte
Saludos Franco Dosil
Posted on May 27, 2019
5 Related Answers
tvtek
Duke
  • 1284 Answers
SOURCE: Samsung lcd 23 inch tv- no picture only sound
Try a reset frist by unplugging for 2 minutes then restart the TV. If you only paid $300 for the TV you will most likely pay more than that for repairs and parts to fix it otherwise.
Posted on Feb 04, 2008
gopakumarg43
  • 76352 Answers
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on May 30, 2015
gopakumarg43
  • 76352 Answers
SOURCE: Insignia TV picture not working but sound is. Flashlight test picture so assumed backlights. Replaced the board for the lights but is still not working. Model ns-50d550na15 part numbers 170452 172770.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Aug 07, 2016
gopakumarg43
  • 76352 Answers
SOURCE: Model number ELEFT506 (Element 50") Problem: 2 month old tv starts to shut off while watching. No picture (black screen) but it has sound. During the flashlight test I can see the picture.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 06, 2017
steveo367421
Steven Brandon
  • 461 Answers
SOURCE: I have a Vizio E550i-52 tv and the screen went black. I have audio, I see no light from the back and when I do the flashlight test I see a faint picture. How to fix?
Hey Matt, It was nice speaking with you on 6YA. If I can be of anymore help feel free to ask. Several other forums I browsed recommend replacing both the LED Driver and the Power Board at the same time and several say one at a time is fine. Replace the LED Driver board then go from there.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on Jan 26, 2017
Samsung tv, model UN39FH5000FXZA. Have sound, no picture, black screen. no backlights. flashlight test shows image. What should I replace?
Lamps in the panel are bad...DON'T order the power supply like someone says on about every post he answers before testing the LED lamps or you will waist a lot of money.
May 02, 2018 | Samsung Televison & Video
I have a Samsung 60" led smart tv there is sound but no picture but you can see shadow of picture with a flashlight. Do you know what part I need? Model # un60j6200afxza. Thank you
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Feb 20, 2018 | Samsung Televison & Video
TV has sound but no picture
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
Jan 31, 2018 | Televison & Video
How to fix a samsung tv
dear my friend if you are electronics technician try to check led back light driver circuit or the back light led inside tv screen .thanks
Oct 03, 2017 | Samsung Televison & Video
I have a Samsung tv model UN60J6200AFXZA with a black screen. I have sound. I did a flashlight test and can see the images on the screen, but no lights with the backlight test. Suggestions?
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Aug 21, 2017 | Samsung Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
No picture only sound on samsung tv
Test it this way. With the TV on and receiving a program, shine a flashlight on the screen If you can observe a faint picture then the T-Con board is working correctly but the back light ballast is not. Some models incorporate the ballasts on the power supply board. Others are on a separate board. Go here to get the correct parts to fix your TV TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
How do I fix my Samsung 40 LED TV that has sound but no picture?
When repairing LED TV Back light assembly you need to contact expert person because lifting of LCD TV panel is very dangerous for non technical person. Be careful
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Televison & Video Logo
Muntejaya Ginting
Muntejaya Ginting
Ekse
