Question about Dewalt Tools & Hardware - Others
Dewalt nail gun light flashes & wont work , but batteries are good ?
Posted by Gary Moores on
5 Related Answers
Anonymous
  • 313 Answers
SOURCE: i have the above dewalt gun just its battery powered, and it doesnt fire the nails
if the nailer is for 18 guage nail use 18 gauge nail if not 16 guage will jam. if it is not the problem is the profile return asyy may jam in side.
Posted on Sep 19, 2008
Anonymous
SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
Chuck Nelson
  • 24 Answers
SOURCE: NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Posted on Jul 07, 2009
Anonymous
  • 8 Answers
SOURCE: nail gun wont fire
First - the air pressure has to be high enough - check the regulator on the tank to make sure it is delivering in excess of 60-70 psi (which I am sure you have already done).
If you have dry fired these guns (i.e. shot them off with no nails in them while you were lubricating them maybe) the mechanism inside could be damaged. I had that happen to one of my nailers (same brand). That was when I learned not to dry fire them...
Since both of them are not working though I would be more inclined to look at the air supply first.
Posted on Sep 10, 2009
Anonymous
  • 576 Answers
SOURCE: Dewalt cordless nail gun fires but doesn't seem to
Try another brand of nails -- maybe your gun doesn't like those. Also, blow any dirt out of the nail magazine.
Posted on Nov 25, 2009
Dewalt nail gun not fireing nails all the way in
What model gun is this? Framing, finish, battery powered?
Feb 28, 2015 | Dewalt Tools & Hardware - Others
Dc628 wont drive nails all the way
Its all about power. If you have air pressure and its the right nail it will shoot. If its oak or maple nope it most likely cant drive it up. If your pressure switch has a 90-120 spread, it will work at 120 and fail at 90. You sometimes can good results by bumping it up 5# or so without the pop off loosing its cool.
Nov 20, 2012 | Dewalt Cordless Finish Nailer Kit
Dewalt dc618 wont fire
firstly its always better to change both of the bands even if one is broken this always keeps the drive trim.all seems well clean all the contacts ie battery and gun (do not use any cleaning products this will cause grease)just wipe clean with paper towel.
Nov 11, 2012 | Dewalt DC616kn 18 - volt 16 - gauge...
The pin on my Dewalt dc616 cordless finish nail gun is ceasing up. How can i lubricate it? can i spray silicon into the nose of the gun?
Hello, W/D here.
The better way is to disconnect the air line from the gun, and place several drops of light oil in the gun while holding the trigger down. Oil daily. Then, re-connect the hose, and fire a few nails into scrap wood.
Another trick is to spray your nails with WD-40 before you load them into the gun.
Best regards, --W/D--
Feb 09, 2011 | Dewalt DC616 16g Cordless 18v Straight...
My nail gun will shoot one nail and then stop shooting.
check with one of your friends that have a nowinly good 18v bat if that dont work check for little pieces of plastic or pieces of the nail that are jamed up by the plunger
Apr 22, 2010 | Dewalt DC618KA Angled Nailer Kit
DEWALT 16 GAUGE ANGLE NAILER WONT FIRE BUT THE LIGHTS KEEP FLASHING
If the light keeps flashing then the battery is not charged enough to fire the gun. recharge the battery or buy a new one if it continues.
Jul 14, 2009 | Dewalt Tools & Hardware - Others
Dewalt dc618 wont drive a nail
Dec 04, 2008 | Dewalt DC618KA Angled Nailer Kit
Dewalt nail gun
if ur nail gun is DC608 it on recall. if it other model it could be the return assy or the pc board.
Sep 10, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Tools & Hardware - Others Logo
222 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
efs_perpends
efs_perpends
john h
Tim Venetis
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
