Question about Yes Televison & Video
Yes I have a question there is a video that is only 20 minutes how do you have this video repeat
Posted by anthony demaio on
Franco Dosil
    Top Expert:
  • Yes Master
  • 10,535 Answers
Hello Anthony, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
If the player is a DVD, you should try the Repeat function and see if it allows you to do the repetition without stopping
In some previous DVDs it was possible to mark the space of what you wanted to repeat and to do it indefinitely, it was indicated as, A_____B Repeat
I wait your answer
Greetings Franco Dosil
Hola Anthony, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Si el reproductor es un DVD, debes probar en la funcion Repeticion y ver si permite hacer la repeticion sin que se detenga
En algunos DVD anteriores venia pa posibilidad de marcar el espacio de lo que querias repetir y lo hacia indefinidamente, venia indicado como, A_____B Repeat
Espero tu respuesta
Saludos Franco Dosil
Posted on May 26, 2019
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
What is a format for downloading a video for samsung yepp t9b
ITS MP4 DUDE - Try Downloading a Video Converter
Digital Player (Recorder) Supported Digital Audio Standards WMA, Ogg Vorbis, MP3, protected WMA (DRM) Supported Digital Video Standards MPEG-4 ID3 Tags Support Yes Playback Modes A-B repeat, repeat shuffle, repeat all, playlist, repeat folder, one track repeat Edit Functions Erase Supported Bit Rate 8 - 320Kbps (MP3) / 5 - 320Kbps (WMA) Response Bandwidth 20 - 20000 Hz Signal-To-Noise Ratio 85 dB Features JPEG photo playback, variable bit-rate compatible, MPEG-4 playback, TEXT viewer Sample Rate 8 - 48 kHz Data Storage Capability Up to 5000 files / 500 folders
Feb 17, 2011 | Samsung Yepp YP-T9 Digital Media Player
From power on, until about 20 minutes warm up, there is a high pitched squeal from the speakers, and random vertical color bars (can't see any video). After about 20 minutes, everything works fine.
There are several weak capacitors in your signal board. You may need to replace as many as 15 or 20 capacitors. You will need purchase a cap checker. Many cases say to replace the signal board. But with great caution and patience a TV tech can do this for you! The power supply board will need one or two capacitors checked and replaced. As for the signal board, yes this is where the problem lies.
Oct 01, 2010 | Polaroid FLM-3232 Television
Engine Light Going On/Off
yes it could cause this
fully charge battery and try again
Apr 04, 2009 | 2002 Harley Davidson FXD Dyna Super Glide
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
20" rca intermitent power
puede ser el mosfet o el optoacoplador
Feb 24, 2008 | RCA 20F420T 20" TV
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
