Question about Fujitsu Heating & Cooling
I have a Fujitsu halcyon DC inverter , model ASU24RLF. It blinks operation: 9 timer: 7 and economy: continuous. 9 months old. ?????
Posted by Robert Hangebrauk on
1 Related Answer
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Fujitsu. Wall mount AC inverter. Operation ,timer,and economy lights all blink, I clean the filters but no change , unit is only 3 months old..
Your AC unit should be still covered by warranty, get the installer to check you AC unit.
Posted on Jan 30, 2012
Fujitsu heat pump codes
Could be low discharge temp or high discharge temp. The first thing you should do is measure discharge temp of air when you have it running. You should have a 20 degree difference between room temp and supply air temp. If you do not, then have flare nuts connections checked. Most likely a small leak in connections from install.That is the first step. If low, leak gets fixed and a new charge weight in per name plate factory charge
Sep 29, 2018 | Fujitsu Heating & Cooling
How to reset outdoor unit fan motor 1 error-Duty error
I just had this problem. There was ice blocking the fan in the external unit. I cleared the ice, cut the power to the external unit to reset it, and everything is working fine now
Mar 26, 2015 | Fujitsu 15RLS - ASU15RLS2 - AOU15RLS2 -...
The red is blinking 8 times and green 4 times. The error charts states PFC circuit error. How can this be fixed ?
Power off at the isolator for 10 mins then switch back on and try again. If error code persists, then it is most likely the controller in the outdoor unit.
Excessive voltage of DC voltage on PFC circuit in inverter PCB is detected, or the excessive current in the circuit is detected.
> Permanent stop.
[Diagnosis Point]
Controller PCB defective (Refer to after mentioned "PFC circuit diagnosis")
Mar 21, 2015 | Fujitsu 15RLQ Halcyon Wall Mounted Mini...
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Dan Webster
Dan Webster
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
