Question about Haier Heating & Cooling
Haier 6050 btu window air conditioner is beeping
Posted by Amy l Long on
5 Related Answers
Anonymous
SOURCE: My Haier 8,000 BTU air
I had that same problem, find the remote and use that to turn it on / off. It solved the problem for me, for whatever reason. You will need to use the remote until the buttons start working again, took mine a few days. I have no idea what was wrong with it.
Edit: I Still get notifications about this 11 years later. I did figure out what was wrong with it. In my case, the E1 notification was because the control panel on the AC was frozen and not working. But the remote control still worked.
Posted on Sep 06, 2008
Anonymous
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
Joe Hogan
  • 10865 Answers
SOURCE: New Air Conditioner is rattles extremely loud
If your air conditioner is new, it is under warrantyl you must contact the store as you dont want to void your warranty.
Posted on Jun 29, 2009
Anonymous
SOURCE: Air Conditioner will not cool. Only fan lights up
My AC seems to be running but it is not blowing cold air out. What maybe the problem?
Posted on Aug 03, 2009
roniecon
Ronny Bennett Sr.
  • 6927 Answers
SOURCE: My air conditioner doesn't produce cold air anymore
It is not enough btu`s most likely,but you can dissasemble the unit and clean it,and the coils.
Posted on Jul 05, 2010
Compressor not running.
Haier Air Conditioner Compressor
modernemporium.urizyme.tk/512124/haier-air-conditioner-compressor
Using a ohm meter, and the compressor is cool to the touch, and the ac is unplugged, Disconnect the wiring to the ... Failure rate on compressors so far not including. ...Haier 12,000-BTU Energy Star Window Air Conditioner with Remote ESA412K-L. Consumer complaints and reviews about Haier Air Conditioner. Since air .
Jul 21, 2015 | Haier ESA412K Window Air Conditioner -...
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
How do I take out the air filter?
The air filter should just pull out from the left side of the air conditioner when you look at it from the front.
The manual for the Haier HWF05XCL is available on the Haier product site: http://www.haier.com/us/products/home-comfort/room-air-conditioners/hwf05xcl.shtml . The direct link is http://image.haier.com/manual/manual_america/home_comfort/room_air_conditioners/201402/P020140226441702402304.pdf . See page 16 (page 18 of the PDF).
I hope this helps.
Aug 16, 2014 | Haier 5,000-BTU Mechanical Window Air...
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Want to know how many btu lca061p
6050BTU
Carrier LCA061P 6050 BTU Thru-Wall/Window Air Conditioner
Jul 11, 2012 | Carrier LCA061P Air Conditioner
I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Jul 23, 2010 | Haier Energy Star ESA3183 Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Larry Blais
Larry Blais
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
