Question about Hayward Pool & Spa
I have a Hayward H100ID. The on off switch seems frozen. Can't turn it on. Second year. Just set up for summer
Try jumping switch for test
Posted by Linda Leseck Elias on
5 Related Answers
Anonymous
SOURCE: Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
Posted on Jun 14, 2009
Anonymous
  • 139 Answers
SOURCE: Fan will not turn on. the heater is a hayward
most likely a faulty ignitor
Posted on Jun 21, 2009
Anonymous
  • 12 Answers
SOURCE: hayward h100ID ignitor not starting
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Posted on Jun 26, 2009
joespools200
  • 246 Answers
SOURCE: heater works fine for 5-10 minutes, then flame goes out
smeel gas? clean burners
Posted on Aug 25, 2009
Anonymous
  • 760 Answers
SOURCE: Just pick up a used Hayward H100id unit from a
Yes you will need new orifices for propane. Part number IDX CNK 1933
http://www.haywardnet.com/inground/products/manuals.cfm
You should be able to get parts there too .
Posted on Aug 17, 2010
Fan won't start and won't ignite I have a Hayward h100id
H100ID fan was stuck. Manually turned fan until it worked loose and sprayed silicone lubricant dielectric lubricant on spindle. Once free turning, it fired right up. We didn't use it all last summer so it probably just got frozen from bugs and such. If it doesn't turn, entire system wont fire.
May 26, 2014 | Hayward H Series Induced Draft Abg 100,000...
Hayward h100id heater will not turn on
Could anyone tell me where on the control panel I would find the Diode D1 on the board?
"agreed; it's usually the diode D1 on the board...a 75 cent part"
May 28, 2012 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Heater will not light
There are several things that can cause this symptom. If you have a volt/ohm meter and call the Hayward technical support at 908-355-7995 they might be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Induced Draft Abg 100,000...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pool & Spa Logo
145 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
