Sansui cd 210.the value of the crystal,x301 used on the main board
Posted by des elkington on
1 Related Answer
mckimani
  • 45 Answers
SOURCE: what is the crystal value used in PSR-E-403
This is the main processing ic (CPU) for the keyboard and hence its not easy unless the company indicates,and unless you are a yamaha dealer this information cannot be rendered to anybody according to their policies.
[email protected]
Posted on Apr 07, 2011
Sansui 53inch tv no backlights
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. https://homenol.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
Mar 26, 2018 | Sansui Televison & Video
Panel light on Bosch microwave out but works fine. I'm just flying blind
I have had sometmes where bad solder connections on the display crystal stopped the display from working. May be worth a look at the connection on the main board where the display crystal is soldered to the board. If not, new main circuit board $$$$. Sharp uses a conductive rubber pad below the crystal to conduct power to the display. It is possible Bosch did something like that too. If so remove the main board, see how the crystal is connected to the board. Clean the rubber conductive pad or look for bad solder connections.
Sep 30, 2017 | Bosch Microwave Ovens
Sansui 0523 lost display, turning on but no sounds
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 14, 2017 | Sansui Televison & Video
I have a sansui PDP42TD1, and i can't adjust the brightness. the whole colour setting is ghosted, can you help?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 26, 2015 | Sansui Televison & Video
Schematic radio shack?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 02, 2014 | Televison & Video
Sansui sv2918
it might be the audio amp acting up when cold they have caps in the audio supply that dont have the correct value till it warms up. that is located on the main board
Oct 15, 2013 | Televison & Video
My Sansui 32" Model LCD32hbw got stuck with the
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Sep 03, 2011 | Sansui 32" TV
I have a CP-X301 mounted for presentations. When I use the "freeze" function, the freeze icon that shows on the screen has moved from the bottom right corner over towards the middle of the...
wholesale and retail all brand projectors and its accessories
Posted on August 25, 2011 by maggie258240135
I am Maggie from Yue Yu Electronic and I am in charge of the export business. Considering we are wholesale and retail all brand projectors and its accessories(lamps, ballasts, DMD Chips, LCD panels, color wheels, remote controls, polarizers, light tunnels, filters, burners, main boards, lens, etc.), we will provide customers with high-quality, low-cost products and better services. We have exported projector parts for many years, and sincerely hope that we could establish a long term and best cooperation with you.
If you have a need, please contact us, including your satisfaction! Hope you have a good business year!
Yours Faithfully
Maggie
Yue Yu Electronics
Mobile: 86-0-15302294942
Address: A1501,1508,NO.592Buynow Building, Tianhe Road , Guangzhou China
Web: www.yylamp.com
MSN: maggie258240135
Mail: [email protected]
Skype: maggie258240135
QQ: 258240135
Aug 24, 2011 | Hitachi CP-X301 Projector
What is the crystal value used in PSR-E-403 Keyboard in DMLCD board/ and the ic number is YMW-767-VT
[email protected]
Dec 26, 2010 | Yamaha Computers & Internet
24 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
