Question about The Watches
My Tac-25 watch switched off and cannot get it work again, the watch is less than a year old
Posted by Pule Ramakau on
Fickster
    New Friend:
  • 37 Answers
Remove the back from the watch and check/replace the battery.
Posted on May 27, 2019
1 Related Answer
David Tolond
  • 2501 Answers
SOURCE: my watch is less than
Whatever is wrong with it, you should be able to have it fixed under warranty (provided it has not been mistreated).
Posted on Sep 18, 2010
I have an automatic raymond weil geneve watch with the yellow chrono, that is less than 2 years old which has stopped working. I wind and wind and nothing. Help please.
this sounds like one of the wheels of the watch movement is broken or else the movement itself needs to be cleaned and oiled up.
Oct 19, 2010 | Watches
There is no display on the watch at all, like the battery is dead but it is less than a year old. Is there some combination of buttons to push?
mcdevito75 here, Sorry, but a watch battery that is less than 1 year old can still be weak or dead, You have to try a new battery first. Battery could have gotton loose, or have dirty contacts. Look for a small watch repair shop in your area. It"s possible you shut the watch off also, Press and hold the MODE button 2-3 seconds see if the display comes back.
Jul 19, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
My Rolex simply quit running a year or so ago. Is there anything besides a complete overhaul that I can do to try and get it running again? What should a typical "tuneup" cost?
First, try manually winding it about 50 turns. If that doesn't get it started it may need cleaning if it's a few years old. In addition to the authorized repair centers there are many fine independent watchmakers who can service it for less money. Depending on the problem it could cost $200 to $500 for repair. It's unusual for the watch to just quit unless it's been damaged somehow, that's why I suggest winding it fully first.
May 24, 2010 | Rolex Daytona 116520 Wrist Watch
IT IS RUNNING SLOW EVEN THOUGH IT'S BEEN WOUND.
If your watch is less than 2 years old then they may service it for free, and if it is that new I would take it back to point of purchase for assistance. Even though Rolex's are Chronometers they are not known for their ability to keep near perfect time. If you are losing only 6 seconds a day then you are still over 99% accurate and it does not really get much better than that (that means you may loose a couple mninutes a month. A watch winder that you set your watch in while not wearing can keep it spinning/ winding and therefore may increase accuracy.
If your watch is loosing a lot of time (half an hour a day) or if the watch is more than 5 years old, it likely needs some servicing. Oils can harden and thicken within your watch and this will affect the performance. Rolex recommends servicing your watch every 5 years or so to keep it in peak condition. A usual service entails a cleaning, oiling and regulating; this usually costs from $350 to $700 depending on where you go and if nothing else is wrong with your watch.
But again, if you are only loosing a few minutes a day, then your watch is still in good shape and I would not recommend paying the money to get it to work only a small bit better.
Oct 20, 2009 | Rolex Watches
Does the movado watch have battery?
unless its a watch u have to wind, which i doubt it is, then u need to test the battery
Oct 06, 2009 | Movado Watches
How much is the capacitor problem in Seiko SNL001 or similar model watches as I get to read reviews abt' capacitor problems appearing in Seiko kinetic watches after 3-4 years and the repair also happens to...
Can be fixed in less than one week and cost is less than $80. See web site for Timelywatch repar.com. They guarantee their work. And yes, the old capacitors are only good for 3-4 years. All replacements are now with a much better, long lasting Lithium Ion battery.
Sep 25, 2009 | Seiko Arctura SNL001 Wrist Watch
My watch the bezel that you change the time / date with, when pulled out comes all the way out, can not change time. Watch less than a year old, can not find the warrenty, not the end of the world, do not...
There are two possible causes: settting lever in your watch is broke/out of engagement or stem is broke. Not a big deal, but watchmakers skills are needed to fix it, as watch must be dismantled.
Any decent watchmaker can do it, so, just find your nearest watch repair shop and ask to fix it. Prices may vary, but no more than 25% of the cost of watch itself.
P.S. It is called Crown or Winding Crown (you say bezel).
Rate me, please.
Aug 11, 2009 | Swiss Army Wenger Sportedge Bracelet Watch
6 year old Casio no. 2271 has ceased responding to buttons
Hi, If you buy some new batteries - i.e. from ebay (very cheap) and replace the old ones - or take tyhe watch into a jewellers and get them replaced (appx. £15) this should do the trick. The batteries should be replaced every 2 years.
Jan 02, 2009 | Casio PRG-40T-7 Pathfinder
Myota Watch Batteries
Try a Maxell 391 silver oxide
Oct 10, 2008 | Watches
Watches Logo
124 people viewed this question
Top The Watches Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
