Question about Radio Communications
My voyager pro keyboard stoped working for no reason
Posted by Scott morris on
1 Related Answer
josh wilson
  • 7 Answers
SOURCE: LG Voyager keyboard backlight broken
The connection between the keyboard and the mother board are loose. You need to take the phone apart and push the connection all the way back in. the connection is also connected to the screens and that might need a good push. Ive done this fix on many LG voyagers and enV's.
Posted on Nov 05, 2012
Half keys stoped work
the ribbon cable to your keyboard has come loose fron theconnector on your motherboard
Feb 04, 2013 | HP ProBook 4710s Notebook
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Electric door on my chrysler 2006 voyager stoped working
check for a blown fuse or bad relay. thats the best place to start and for sure the cheapest.
Jan 24, 2012 | Chrysler Cars & Trucks
My voyager pro doesnt work with my skype on iphone.
It may have to do with the settings that are listed on Skype. Because you are using the headset with your phone, it should work with the Skype application, so please check your settings. If it continues to not function correctly, try re-pair or subscribing again.
Below are two links which may help you solve your issues:
Plantronics Voyager Pro User's Guide
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Jul 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have Plantronics voyager Pro headset. The microphone is not working. The receiving end cannot hear me
Try deleting your Plantronics Voyager Pro from your phone and then repair them to each other. Sometimes this does correct any issues you may be having. The link for the user guide is included below.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I wiped my coumputer and my 99926 web pro mouse by fellowes stoped working.
For further advise i would consider using dust remover to clean any electrical system.
Oct 25, 2010 | Fellowes Manufacturing 99666...
Jun 10, 2010 | LG VOYAGER VX10000 Cellular Phone
I have a hp compaq vista A900 notebooke keyboard stoped workin
there is no reason the keyboard should have stopped working unless something in the form of a liquid solvent was introduced into the keyboard area. Call the store where you purchased it or take it back along with your receipt for a warranty exchange.
Jun 16, 2009 | Compaq Keyboard
LG Voyager
here is what tekurly said
Actually, all Verizon phones are unlocked.
By unlocked, I mean that you can access the service programming for the Voyager.
The service code is 000000.
To program the Voyager, do the following:
From the keyboard, type
##program10000
Next, enter the service code.
I saw a post from a Voyager-Lg.com member who said he was using the Voyager on another phone service.
Anyway, be careful...
Aug 13, 2008 | Cell Phones
Radio Communications Logo
131 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Radio Communication Expert? Answer questions, earn points and help others
