Question about Car Audio & Video
Wiring diagram mtd1998 z16 ignition switch6tab switi I have red\black stripe?ch
Posted by Roy hill on
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
Anonymous
  • 405 Answers
SOURCE: 1992 Isuzu Rodeo Radio Wiring Diagram needed.
http://www.the12volt.com/installbay/vehicles.asp try this site out and see if it will help you.
Posted on Dec 29, 2008
Anonymous
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
Anonymous
  • 82 Answers
SOURCE: 87 regal ignition switch wiring diagram
Thick wires at IGN SW .... Red(s) - supply power from the battery to the IGN switch ... Pink - ignition supply ... Orange - Accessory power ... Purple most RWD sometimes (Yellow most FWD) - Starter .. Did I miss any? It's been a while The thin wires on the IGN swich are for key sense and VATS (if applicable)
Posted on May 08, 2009
Anonymous
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
Pioneer deh-m8497 wiring diagram
Red is ignition yellow is battery black is ground blue is Remote turn on orange is illumination if it has one.... speaker wires are white and white with black stripe our front as is gray and gray with black stripe back speakers are purple with black stripe and green green with black stripe.
Sep 11, 2018 | Pioneer Car Audio & Video
1994 Suzuki GSXR750 wiring diagram
Hi, Thomas for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1994 Suzuki GSXR 750 wiring diagram Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki GSX R750W 1993 Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 17, 2018 | 2008 Suzuki GSXR750
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
Wiring in a sony CDX-L600X in a 95' F150
red is B+
black is ground
dark blue with white stripe is remote for amp
blue is power antenna
yellow is ignition
white and white with black stripe is front left
gray and gray with black stripe is front right
green and green with black stripe is back left
purple and purple with black stripe is back right
this is for the deck
Mar 21, 2010 | Sony CDX-L600X CD Player
I need the radio wiring diagram for a 1992 cadillac eldorado. the wires i have are: black w/ white stripe, yellow, green w/white stripe, green, brown, 2 brown w/ white stripe,black on one plug the other...
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
Feb 10, 2010 | 1992 Cadillac Eldorado
Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Jan 14, 2010 | Ford F-250 Cars & Trucks
I need a wiring diagram for a Pioneer DEH-P200 CD player/reciever
Memory: yellow Power: red Ground: black
Front right +: white
Front right - : white w/ black stripe
Front left +: grey
Front left -: grey w/ black stripe
Rear right +: purple
Rear right -: purple w/ black stripe
Rear left +: green
Rear left -: green w/ black stripe
I think this is what you mean by wiring diagram, Hope it helps
Oct 17, 2008 | Car Audio & Video
Wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Nov 30, 2007 | Clarion DRX5575
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
