SOURCE: stav-3970 receiver puts out no sound regardless of inputed component.
The audio amplifiers ICs are damaged .
SOURCE: left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
SOURCE: Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
SOURCE: Problems with int 5.1-Channel Home Theater Speaker System
yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
