Question about LG Refrigerators
LG LFX25960ST water dispenser works but no water into icemaker. what is wrong?
Mark Cantrell
    New Friend:
  • 33 Answers
There is a small plastic hose running from the back of the ice maker into the ice maker tray that may be loose ?
Posted on May 24, 2019
  • Mark Cantrell
    Mark Cantrell May 24, 2019
5 Related Answers
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
betz73
kristopher betzler
  • 298 Answers
SOURCE: Icemaker not getting water
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
Posted on Aug 21, 2008
docjohn174
john gagnon
  • 943 Answers
SOURCE: lg lfx25960st water dispenser stopped
hi. thanks for the question . i would look at the water valve at the back of the fridge. replace the valve .thanks the appliance doc
Posted on Oct 05, 2008
Anonymous
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 14, 2010
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
Oct 19, 2009 | LG LFX25960ST Stainless Steel French Door...
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Icemaker does not work
Does your unit have the cube size selection button inside of the ice maker door , if so is it lit up, if so is it on a cube selection. If not that is the reason the ice maker is not working because even though the unit is on the cube selection has not been made. This should solve your problem.
Jul 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
Ice maker fails to make ice tried several times to turn switch on and off water flows to the cold water dispenser worked OK for the past several months what to do??
I hate to say this but from experience on LG icemakers if the fingers aren't turning or the if you have the flextray model the only fix is a new icemaker. Make sure the fill tube to the icemaker is not frozen also.
Oct 23, 2007 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
77 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
