Question about Car Audio & Video
The only buttons are : seek up - seek down - and a large M
Posted by Clive Webster on
Downloaded manual for Kenwood KDC-MP528, but instructions for setting clock time is sketchy, and can't get " clock adj." to come up, no matter in what sequence I hit instructed buttons....
Try putting the radio in standby mode and then hold the menu button in for a few seconds. Once you enter the menu, use the am or fm buttons to scroll through the menu. Then hold the seek up or seek down for a few seconds until the clock flashes, You should then be able to use the am/fm buttons and seek up and down buttons to set the hours and minutes. Once you have the time set, press the menu button again.
Aug 03, 2011 | Kenwood KDC-MP528 CD Player
How to turnn off the change oil light
For this year and model what you want to do is the following
1. Turn your key to the On or ACC position and turn off the radio.
2. Press TUNE DISP button on the radio and hold it in for about five seconds. The word "Settings" should display. Then press the "Seek Ptype or "Seek Pscan" up or down arrow to scroll through the menu.
3. Keep scrolling until the menu reads "Oil Life" on the display. Push the "Prev" or "Next" button to go to sub-menu. You then want to press "Seek Ptype" or "Seek Pscan" up or down arrow until you find "Reset" displayed.
4. Now, press the "Tune Disp" button to reset the oil light. A chime will sound letting you know the light is reset, and "Done" should show on the display.
5. Scroll with buttons until "Exit" appears on display. Press "Tune Disp" to end program. Another chime will sound.
DONE
You can find more oil reset procedures at Oil Light Reset
Mar 04, 2011 | 2002 Chevrolet Impala
Setting the clock
press and hold the menu button for a few seconds. use the am/fm button to scroll through the memory, when you get to the clock, press and hold either the seek up or seek down button for a few seconds. use the am/fm buttons to set the hour and the seek up or down to set the minutes. when you are done. press the menu button. if you want to exit the menu, press the menu button once again.
Jan 30, 2011 | Kenwood KDC-MP2032 CD Player
How do you set clock on the kenwood kdc mp425
press and hold the menu button for a few seconds. when the menu comes on the screen, use the am/fm buttons to scroll through the menu. when you get to clock set, press and hold the seek up or seek down button for a few seconds. when it starts flashing, use the am/fm buttons to adjust the hours and the seek up and down to adjust the minutes. press the menu button again to set. then press the menu button once again to exit menu mode.
Oct 13, 2010 | Car Audio & Video
I have a BOSS BV9455 that keeps on seeking then goes around the stations and comes back to the one it was on, this goes on and on, What to do please????
Turn the manual seek option on. Typically you need to hold the seek button down for a couple seconds and then something like an M should flash and then you go through and push the seek button one by one.
Sep 24, 2010 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
How do i set the clock
press and hold the menu button for a few seconds, then use the am/fm buttons to get you to clock set, then press and hold the seek up or seed down button for a few seconds. use the am/fm and seek up and down buttons to adjust the time. press the menu button to set.
Aug 24, 2010 | Kenwood KDC-138 FM / AM Receiver
How do i set the clock on my kenwood kdc-mp5032?
press the menu button for a few seconds until the menu comes up, then using the am or fm buttons scroll until you reach clock, then press either the seek up or down button untill display flashes. then press the am/fm buttons to set hour and seek up or down to set minutes. when finished just press the menu button againl.
Dec 09, 2009 | Kenwood KDC-MP5032 CD Player
WANT TO SET MY CLOCK
depending on model the following may work:
With the car turned off, hold down the RCL button on your radio.
then press the AUTO/TONE or TUNE/SEEK button to change the time
Nov 17, 2009 | 2005 Saturn VUE
Setting the clock
with radio off, push both large buttons, press set, press the scan and seek buttons to set.
Jun 25, 2009 | 1992 Buick Park Avenue
'89 Tbird Clock
I believe that if you HOLD DOWN the "clock" button and press "seek" for minutes and "tune" for hours you should be able to reset your clock. Remember that if you press the + "seek" you will increase the minutes and if you press the - "seek" you will decrease the minutes. The same for "tune". The left will decrease and the right will increase hours. If this doesn't work, there is something wrong with the contacts behind these buttons, or some other problem.
Good luck.
Jul 15, 2008 | 1989 Ford Thunderbird
Car Audio & Video Logo
94 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
