Question about Boating
F code on remote minnkota riptide 55lbtrolling motor what is it
Posted by Philip Chiu on
john Benson
    Sergeant:
  • 184 Answers
Try the following.
Ensure the connector going to the controller is secure.
Remove power to the motor by stowing it. Wait until the remote screen goes blank. Deploy the motor to power it up verifying that the System Ready light comes back on when the motor is deployed.
Press any button on the remote to turn it on.
If F code returns then probably controller board will need replaced.
Posted on Oct 26, 2019
3 Related Answers
Editor925
Dean
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
Larry O'shields
  • 6 Answers
SOURCE: I have a Minnkota Riptide 80# thrust trollmotor.
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Posted on Nov 24, 2009
snowghost1
chris wheeler
  • 784 Answers
SOURCE: I have the Minn Kota
if it is not steering with the remote - then the problem could be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
the best way to trouble shoot the unit would be to open the case and use volt meter to trace the voltage flow. also make sure you are getting power to and thru the remote as I have seen the control buttons go bad.
if you are still having troubles and have more questions - please feel free to write me back here and I will do my best to walk you through the steps needed to fix or trouble shoot more.
have a great night,
c...
Posted on Feb 21, 2011
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota
    I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
    May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
    Looking for parts brakesdown minnkota 101
    Google the Make and model...dozens of web sites, including MinnKota,
    Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
    Nov 23, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Online manual needed
    I have minnkota riptide i had to take the handle off and a little spring & white plastic piece poped out of the handle i just wanted to see where it goes
    Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Looking 4 a manual on a minnkota turbo pro 824 48 lbs thrust motor
    This isn't my usual area of expertize, but is this what your looking for?
    Minnkota 824 Motor Diagram
    Mar 20, 2009 | Computers & Internet
    Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Boating Logo
    193 people viewed this question
    Top Boating Experts
    ray gallant
     vpsoccer
    vpsoccer
    Andrew Taylor
    Andrew Taylor
    Are you a Boating Expert? Answer questions, earn points and help others
