Question about Measuring Tools & Sensors
Can I replace the LCD screen in the lacrosse weather station model :c83332
Posted by Robert schiskey on
5 Related Answers
tina gallow
  • 126 Answers
SOURCE: I cannot find my user
You can dowload this manual
at the site below.
http://manualgeek.com/
Posted on Dec 14, 2010
Okeoma Emmanuel
  • 1156 Answers
SOURCE: My weather station by Lacross will not display the
http://www.lacrossetechnology.com/9611/manual.pdf
If that's not the right manual,you can use the link below, and select the model..If the model is not there, that means the manual is not available...
http://www.lacrossetechnology.com/support/manuals.php
Take care
Posted on Jun 15, 2011
Ray Nardo
SOURCE: Sharp Weather Station Model SPC344 The outside
After inserting the batteries, DO NOT set the time until the OUTSIDE temperature registers. That's the trick.
Posted on Nov 06, 2011
richie46
  • 12962 Answers
SOURCE: I lost instructions for my LaCrosse weather station WS916OU--IT
Go to website for download.
Posted on Jun 25, 2017
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Lacrosse weather station model T85647
Either the sensor is defective or the receiver is, toss a coin.
Posted on Jun 30, 2017
Guide for lacrosse technology model c83349 weather station
link to manual
https://www.lacrossetechnology.com/media/catalog/product/c/8/c83332-c83349.pdf
May 15, 2018 | Measuring Tools & Sensors
How do i reset high temp on lacross weather station
https://www.lacrossetechnology.com/products/weather/weather-stations
Dec 25, 2017 | Measuring Tools & Sensors
LA Crosse manual for weather station 308-1414
Most LaCrosse weather station manuals are available here: http://www.meade.com/support/manuals/ or on the product page (see the Support tab). Using the search feature on the support page, I found three models which start 308-1414. Two of these differ in the color of the case of the weather station. Hover over the picture of any of these weather stations and click on the More button to go to their product page. The direct link to the manual for the 308-1414MB is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414m.pdf . This product page is http://www.lacrossetechnology.com/308-1414mb-weather-station/ . The manual for the 308-1414W/308-1414B is http://www.lacrossetechnology.com/media/catalog/product/3/0/308-1414.pdf . The product page for the 308-1414W is http://www.lacrossetechnology.com/308-1414w-weather-station/ .
I hope this helps.
Jul 10, 2017 | La Crosse Measuring Tools & Sensors
The outside transmitter for my Lacross weather station, model WS-9080U-IT is not working. I replaced the batteries. How do I get it to transmit?
First remove the batteries and wait 5 minutes and then try again. If still no success, make sure that you are close enough to the sensor, take the sensor inside to the readout and see if it picks it up. If it does then there may be interference.
Dec 21, 2016 | Measuring Tools & Sensors
What does an OF symbol mean in the indoor temp window with no readings from the outside?
Based on a different, but similar, LaCrosse model (the WS-8611), it would appear to be an OverFlow indication, meaning that it's out of range. Here's a quote from that unit's manual:
SPECIFICATIONS:
Temperature measuring range:
Indoor : 14.2F to +139.8F with 0.2F resolution
(-9.9C to +59.9C with 0.1C resolution)
("OF.L" displayed if outside this range)
Outdoor : -39.8F to +139.8F with 0.2F resolution
(-39.9C to +59.9C with 0.1C resolution
It is likely that their convention remains the same across models, but I don't work for them, so I can't guarantee it.
Sep 25, 2014 | La Crosse LaCrosse Technology Weather...
Auriol weather station
Hi Bogdan.
i think the LCD is not good.
if it is possible to replace it???
regards.
nuwan
Jan 20, 2014 | Measuring Tools & Sensors
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
Measuring Tools & Sensors Logo
138 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
