Nokia 5800 XpressMusic Smartphone Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia 5800 keeps flashing the notification light, but there is no new activity. I have switched it off and check for all missed calls etc
  • hatmanchris May 11, 2010
    I will need more clarification to be able to attempt to help you, such as if you have done any SEEM editing used any p2k programs on it; or if you have simply dropped it (and if so how hard/far) you know basic info.
    I can on no terms guarantee that i can fix it, but i will try to help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 11, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
547
Points
5
Goto Settings. Select Phone. Select Notification Lights and then turn off Breathing Light. Job done!
Anonymous
Level 2:
Sniper:
  • Expert 111 Answers
  • Posted on Aug 08, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
111
Questions
Helped
27308
Points
374
Try to turn off info message notification..
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Press*#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 • Cell Phones
Nokia 5800 keeps switching on and off
Try it with this tricks......First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download 2700 flash file from this link Nokia flash file select BB5 and choose your model and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
1helpful
Call restriction activated on incoming and outgoing calls how to lift call restriction
Try this
Go to Settings>Calling>Call Barring
Press Option and select deactivate all barrings
But a notification will appear to contact your service provider.
You can ask them the barring code or let them deactivate it
1helpful
2answers
How to activate my mms and gprs NOKIA 5800? Go Nokia 5800,,1234 send to 2951? but the reply is invalid. how?
try to call your service provider and tell them what was happened..they will send you a gprs and mms activation..
1helpful
Is my menu button meant to illuminate every 30 seconds or so even when there is no unread messages or missed calls? havnt noticed it b4
this is a setting that can be de-activated from under settings.
it is called the breathing option, it is to make the phone appear like it is breathing like a human being. to de-activate this function do the following
1.go to settings
2.go to phone
3.then proceed to notification lights
4.click on standby br. light
5.switch off breathing light
hope this helped you?
please rate
8helpful
2answers
My nokia 5800 xpress screen keeps flashing every 8 seconds but no messages or calls help plz.
You may have set your Nokia to "Breathing"- the slow pulsing light is a kind of "stand by light". See more here: http://thenokiaguide.com/2009/04/28/nokia-5800-xpressmusic-firmware-version-210025-now-available/
2answers
My nokia 5800 xpressmusic phones playing up(insert sim)
please check whether you have inserted the Sim card correct. or it must be the Sim card readers problem.you must go to a nokia dealer before the warranty gets over.
please rate me!
1helpful
Nokia 5800 - calls always divert to answerphone
Go to call settings>>Call Divert. and cancell all diverts.
2helpful
No notification of missed calls and messages
backup ur contact & Phone memory then enter *#7370# phone want the security code then enter 12345 ( if u no Change it ) phone will restart. then open log/setting/and set 10days. it will be ok
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
