The CS5111-2 isn't an answering machine. If you have a separate answering machine connected, please refer to its documentation. If you subscribe to a voicemail system offered by your phone company, please contact them for instructions.
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Call your KX-TM150B answer machine, it will answer after 15 rings if it has power but the answer function is turned off. The greeting will play and the answer function will turn on. I have included a link where you can download the manual.
how to turn off answering machine in Samsung C3212 and 3212i?
First go to setting then select no 6 application setting then go to no 1 Call again select no 1 All calls and select no 4 Answering machine. now go to no 2 setting and deactivate the answering machine through selection off key.
