Question about Acer Televison & Video
Hello, what is the hard reset procedure on factory settings with a video projector ACER V9800, with the remote control plantes and more screen display and not OSD, thank you very much for your help
Hard reset factory ACER V9800 UHD 4K
Posted by Sae Sae on
Shamim Mia
As Bob Myers mentions, the question can't be answered unless you explain which video output the camera has. The solution for a BNC CCTV camera would not be the same for a PoE IP camera. Provide that information, and we can suggest hardware that would connect your TV sets and project to the camera feed.
Posted on May 15, 2020
5 Related Answers
lukster
Luther Stephens
  • 217 Answers
SOURCE: on screen display on monitor locked and need to restore factory settings
Hold the menu button down long enough and it should unlock, if it unlocks and then locks back up immediately, you have a problem on the main board
Posted on Mar 17, 2007
Anonymous
SOURCE: htc touch diamond non responsive align screen after hard reset
its easy i had the same problem and i fixed it the same day.u just hav 2 clik on the 4 corner of ur phone and its gonna ask u do u wanna save it or not then thts all all and u move onto the nxt step
Posted on Nov 05, 2009
Anonymous
SOURCE: Install problems at AVR 142
ensure that you have the reciver connected to a display monitor e.g t.v. set, there you'l be able to make all the necessary ammendments.use the video out or use the HDMI out to connect to your t.v.
which speakers are using for the avr 142?
Posted on Jan 03, 2010
Anonymous
SOURCE: how do i reset my acer travelmate 5520 to factory
start computer when acer logo appears press F2 to go into BIOS settings scroll across to BOOT top menu bar with the arrow buttons scroll down to D2D enable/disable change to enable and ENTER. save and exit. restart computer once again when acer logo appears press <Alt>+<F10> at the same time to enter the recovery process, refer to on screen instructions to recover system.
Posted on Jan 27, 2010
Anonymous
SOURCE: Acer projector P3150 locked with passwd
Read some Acer manual and it says:
Administrator Password
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
Posted on Jan 29, 2010
How can i reset my aucma tv without remote
Without a remote control, you can't do a reset.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 25, 2017 | Televison & Video
Vision quest TV, online I can't find a remote that it will program too and it is key locked. Any button I push an icon displays on the screen key locked. Hard reset pattern?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 04, 2017 | Televison & Video
Factory reset - without remote NEC p553 monitor
You can't do it without a remote control. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
http://electro-medical.blogspot.com/
Oct 28, 2016 | NEC 55IN P553 LED LCD PUBLIC DISPLAY MNTR...
Sharp LC-26AD5E-BK Upon switching TV on screen displays: "Software Update through PC/UART" & "Connecting to host". TV is non responsive to remote control and am unable to exit screen. Please help.
Try a hard reset to this set, and then check. If it do not help you; contact the authorized service center for sharp. Firmware update might be necessary.
Jun 15, 2016 | Sharp Televison & Video
How to set my sansui tv back to orig.factory? Cuz my tv dont adopt my remote control. & my tv screen hav a factory word that cant be deleted?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. To enter the service mode, you should have its remote control. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 01, 2016 | Televison & Video
How to PCB reset hitachi 42 " plasma tv i dont have the remote and the panel button lock is set on...so the panel buttons wont work.... Any way to fix it ?
Without its remote control, you can't make a reset to this set. In fact; a hard reset procedure do not want a remote control, but,. if you wish to make a system reset [Factory Reset]; there is no other way without a remote control.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
To get more details about remote controls. visit these sites.
Remote Control Codes
Electrohelponline
Nov 25, 2014 | Televison & Video
How do I factory reset my Sylvania TV SST4324 to TV mode?
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
Sep 23, 2014 | Sylvania New Original SST4324S Remote...
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
Projector only in stanby mode does not switch on
This projector provides two different remote control codes; the factory-set, initial code (Code 1) and the secondary code (Code 2). This switching function prevents remote control interference when several projectors or video equipment are operated at the same time.
When the projector is operated in "Code 2," both the projector and the remote control must be switched to "Code 2." To change the code for the projector:
Select either "Code 1" or "Code 2" in this Setting Menu.
To change the code for the remote control:
Press and hold both the MENU and IMAGE buttons together for more than 5 seconds. After changing the code, make sure the remote control operates properly.
Remote control
Press and hold MENU and IMAGE buttons for more than 5 seconds.
You can change the brightness of the screen.
High ...... Brighter than the Normal mode
Auto ...... Brightness according with the input signal
Normal ... Normal brightness
On start
Note:
•When different codes are set on the projector and on the remote control, any operation cannot be made. In that case, switch the code on the remote control to fit the code on the projector.
•If the batteries are removed from the remote control for a long period of time, the remote control code will be reset.
Mar 12, 2013 | Office Equipment & Supplies
Nu-Tec TV/DVD Combo
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Sep 03, 2017 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Acer Televison & Video Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Paul Bade
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
