Question about Nerf Toys
My sons nerf stryfe won’t stop reving,any idea how to fix it?
Posted by Troy Burnett on
Mark Cantrell
    New Friend:
  • 33 Answers
Is there a Nerf round stuck in the mechanism
Posted on May 25, 2019
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
My sons chain won't stay on and it falls off when
Being a physical problem and lacking any clues about the bike we'll need you to observe and judge what is really happening to make the chain fall off. Use a search engine for "bicycle chain falls off" to get some ideas and guidance on identifying the dysfunction, then the fix(es).
Aug 09, 2011 | Cycling
My Nerf Nite finder laser doesn't work, we have the batteries in and in the correct way. Any ideas please????
Here's one--
Although I am not completely familiar with the internals of the NERF NIGHTFINDER I have a good idea what is wrong.
Sometimes factories screw up, etc...
Lemme get to the point.
The circuit operating your light (if you don't know what that is look it up and find out) is probably not connected. Open up the laser and look online at what the internals look like. Make sure that the circuit is complete.
That's all, email me at [email protected] for more info on modding and nerf guns.
Jan 31, 2011 | Nerf Nite Finder
Engine reving and dying at stops
may need new spark plugs and wires and if that dosent fix it try changing your fuel filter.
Apr 21, 2010 | 1993 Acura Vigor
Eng stays reved up when coming to a stop
you have sticky carbs or an air leak on the inlet manefoulds take the bike right back and have words with the guy who "fixed it!" like jently grad him round the neck and bang his head onto a wall till he gets it right this time you payed good money for the fix,, go back and get it done right
Jan 18, 2010 | 2007 Yamaha V Star Classic
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Nerf controller
Hi Rayjdawg,
Check the battery pack on the back of the controller. It's been known to not have good contact at times. I would also try changing the battery. Good luck. :)
Jan 02, 2008 | Computers & Internet
Toys Logo
167 people viewed this question
Top Nerf Toys Experts
MODERATOR Canada
MODERATOR Canada
WORLD MODERATOR
Alyssa DeWolfe
Alyssa DeWolfe
Level 1 Expert
Are you a Nerf Toy Expert? Answer questions, earn points and help others
