Question about Watches
To find a store in Cornwall, On. For wrist and thumb support
Posted by Micheline Schlybeurt on
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
Tip
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
on Oct 10, 2010 | Rolex Oyster Perpetual Submariner Date...
Where can I buy a new Wrist band WA00-22-005?
You can order it online. There are number of online stores of various popular brands. If you want do to offline shopping then also Google will help you in finding a store in your vicinity from where you can buy wrist bands.
http://streetlegaltshirts.com/movies.html
Nov 19, 2013 | Nike Oregon WA0022-005 Wrist Watch
I broke the wrist band of my BL5119-52E Titanium watch... Need new wrist band. Where and how much ?...
Most Citizen Authorized dealers locally can order this band for you.
Unfortunately, most do not have the skills or Certified Master Horologist on staff to install it for you properly. If you know how to install it, or would like to attempt it you can save some money and order it directly from Citizen yourself by providing the model number and calling: 800-321-1023 extension 2.
I would recommend having a Certified Master Horologist install it for you.
The cost, as a rule of thumb, would be 50% of the original retail price of the timepiece, plus shipping and handling.
Feb 23, 2011 | Citizen Modena Eco-Drive BL5110-52E Wrist...
I have a Nike team VJ320010 wrist watch that needs a new band. Where might I find that replacement? Thank you! Colleen
If you go to their web site, (www.nike.com/timing) you will find a store locator on the "Support" page.
You should be able to find your nearest store. If there isn't a convenient one then you could send your watch to a service center.
Feb 15, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
How do i put on the wave ceptor ?
This depends on what you mean by your question.
To adjust the size of the band, if you look on the inside of the links (the side that goes against your wrist), you will find that at each link joint, there is a spring-pin (like the traditional pins for attaching bands to watches) which can be easily removed.  Remove the necessary number of links to size the band to your wrist.
To put the watch on your wrist, merely position it as desired, and, close the clasp by grasping the outer buckle with your fingers, placing your thumb against the mid-segment, and squeezing the two together. Then, move that assemblage upwards toward your wrist.  Move your thumb out of the way as it approaches closure and push it together until the outer buckle clasp clicks into place around the stud on the inner segment.
If you are asking how to get the watch to receive the time from WWVB, this will happen automatically once per day (three attempts per day until one is successful).  If you want to manually trigger an attempt, this can be accomplished by holding the "RECEIVE" button for a few seconds until the watch beeps and the display reads "RC!".  It will then attempt to receive the signal from WWVB for several minutes and calibrate if successful.
You can identify whether the last synchronization attempt was successful or not by the display in the lower right corner while the time is displayed.  It will show an antenna and three bar-graph segments if it was successful, or, be blank if it was unsuccessful.
If you mean something else by "put on the waveceptor", I'm afraid I don't understand your question.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
Dec 19, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Broken wrist band
The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Band adjustment
I was able to take use a push pin (thumb tack) to get out the (split) pin. I put the thumb tack in the hole of the pin I wanted to remove, place the thumb tack upside down on our counter top and gently but firmly push the pin out. It only has to push out an 1/8 of an inch and then you can pull it the rest of the way. Thanks to the diagram that "guest" posted above - I copied and pasted: http://www.pmwf.com/Watches/WatchSchool/WS%2014%20How%20to%20Resize%20Common%20Bracelets/WS%2014%20How%20to%20Resize%20Bracelets.htm#Split%20pin%20bracelets in the browser and it showed me how the pins work in the wrist band. Didn't need all of the fancy tools. (:
Aug 18, 2007 | Fossil CH2331 Wrist Watch
Watches Logo
113 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
