Question about Tablets & eReaders
Yes I ha e the allwinner android tablet pc when I turn it's starts up but won't go any further than the boot screen
Posted by Dan Vaughan on
Akbar Mughal
    Master:
  • 533 Answers
It have software problem. it required new software....
Posted on May 23, 2019
3 Related Answers
brimknows
Jason Fisher
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
mhrasna
Hunny Bunny
  • 99 Answers
SOURCE: 9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Posted on Nov 11, 2014
BENTECH7
Ruben Balisbis
  • 132 Answers
SOURCE: HAVE JUST REPLACED SCREEN ON 9 INCH A23 ALL WINNER ANDROID TABLET BEEN TOLD IT NEEDS RECALIBRATING AS NEW SCREEN NOT WORKING CORRECTLY VIA SCREEN PRESSING EXIT SCREEN NOT TURNING OFF
Calibrate through settings. Check if the flex of a touch sensors installed properly.
Posted on Mar 20, 2015
FACTORY RESET
Does this tablet have a volume control button? If so this is the reset instructions
Hold down the Power button and tap Volume Up. You'll see the Android system recovery menu appear at the top of your screen. Select wipe data / factory reset with the volume keys and tap the Power button to activate it. Select Yes - erase all user data with the volume buttons and tap Power.
Jul 21, 2016 | Tagital Taital TM 7 Inch Dual Core Tablet...
Gets stuck on "android" page when I turn it on.
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung Sometimes Android phones get frozen or stuck on their loading screens. This isn't too common of an issue with Samsung phones running on the Android operating system ...
  • Android- Samsung S4 stuck on reboot page: [ Samsung Galaxy ... www.usoftsmartphone.com/t437669.html
    • 1 POST
    • FIRST POST: 2016-02-29
    2016-02-29 · UsoftTech :: WwW.UsoftTech.CoM :: Samsung S4 stuck on reboot page My Samsung S4, when turning it on, asked me for a password - I entered my password,
  • Android Tablet stuck on boot screen ! Bypass it in easy ... www.youtube.com/watch?v=HErn0-GcQqE
    • BY MY TABLET GURU
    • 5 MIN
    • 427K VIEWS
    2014-01-04 · Want to watch this again later? Sign in to add this video to a playlist. If your Android tablet is stuck on startup or boot screen, then bypass it using ...
  • Videos of stuck on android page bing.com/videos zClick to view 9:29HD Android tablet stuck on Android Logo Fix YouTube ",p:"https://www.youtube.com/watch?v=S1i58AUKn60",ns:"video",k:"5008",st:"http://tse2.mm.bing.net/th?id=OVP.V11b29ac3cbace951076efa80a90d359c&pid=15.1",stw:300,sth:168,du:"0:51",hd:"HD",vc:"188,000+ views",r:"720P",ha:"b3e2a9d9d6e95cc24bb8b87cd1bf38c9"}'>zClick to view 0:51HD Tablet stuck on Android introductory screen YouTube ",p:"https://www.youtube.com/watch?v=HErn0-GcQqE",ns:"video",k:"5008",st:"http://tse3.mm.bing.net/th?id=OVP.Vfe84da1cf9b5dae40aecc46e6d21fc17&pid=15.1",stw:300,sth:168,du:"4:36",hd:"HD",vc:"421,000+ views",r:"720P",ha:"0676f504c9fa13927a5854467b9fdc5a"}'>zClick to view 4:36HD Android Tablet stuck on boot screen ! Bypass it in easy steps. YouTube 2q==Click to view 3:50 How to Fix Stuck On Boot Start Screen Problem in Android ... YouTube See more videos of stuck on android page
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Enthusiasts Stack Exchange is a question and answer site for enthusiasts and power users of the Android operating system. It's 100% free, no registration ...
  • Mar 04, 2016 | Tablets & eReaders
    My android dual core jelly bean box is stuck on the start screen
    Press the reset button using a paper clip. Look for a tiny hole usually on the back or side of the tablet.
    Mar 03, 2015 | Allwinner A20 7inch 7V Capacitive Touch...
    Irulu tablet support
    Charge it for at least 12 hours first.
    Aug 12, 2014 | Irulu 10.1 inch Android Tablet PC, 4.2...
    My tagital tablet stuck on android screen
    Hold down the power button for 30 seconds and then turn it back on.
    May 01, 2014 | Tagital TM 7" Android 4.0 4GB MID...
    My allwinner a20 keeps freezing when i switch in on
    Turn off, then hold down vol up and power button until you see the droid, release it will continue to boot to a memu. Select reboot.
    Apr 30, 2014 | Allwinner A20 7inch 7V Capacitive Touch...
    How can I reflash the firmware for my Allwinner A13 tablet?
    Try pressing and holding power and volume down until it boots up. you will need to go online from a PC to download the latest firmware ( look on Allwinner webpage) then download it to a formatted SDcard.
    this works for Ainol tablets.
    worth a try.
    Feb 28, 2014 | Tablets & eReaders
    Allwinner A20 dual core android tab screen want rotate
    Allwinner A20 is a name of a processor, so I'm not sure what tablet are you using.
    There is an option to block rotation, for example if you want to read an e-book while laying on your back. Go to settings and try to find an option to unlock rotation.
    Also, some tablets have a hardware (physical) switch on the side that locks rotation.
    Jan 17, 2014 | Samsung Galaxy Tab Tablet PC
    Tablets & eReaders Logo
    Top Tablets & eReaders Experts
    Marvin
    Marvin
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
