How to get a 32in' phillips tv model no.32HFL5662L/F7 OUT OF HOTEL MODE WITHOUT A REMOTE FOR IT
PURCHASED IT AT A HOTEL REMODELING SALE NOW CANT GET IT OUT OF HOTEL MODE AND HAVE NO REMOTE. IS THERE A WAY TO FIX IT OR DID I LOSE MY MONEY?
Posted by P BREW on
5 Related Answers
Anonymous
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
Anonymous
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
3764alan
Alan Spicer
  • 127 Answers
SOURCE: how to convert a phillip tv from hotel mode to
people stop stealing motel tv's!!!!
Special TV's made for that purpose are manufactured that way. There is no converting them. Give it back.
Posted on Nov 22, 2009
Anonymous
SOURCE: My tv phillips model prf227 s325 i have
type in the code 319753 followed IMMEDIATELY by the MUTE button. The number sequence and mute button must be done within 20 seconds of each other. Once you hit mute a new menu will appeal click on CHANNEL INPUT (should be the third one down) then a new menu will come up and click AUTO PROGRAM at the bottom, this will go through all the channels (up too I think 90?) and unlock them one by one.
Posted on Oct 30, 2010
JEFF MCINTOSH
SOURCE: my model is 32HF7945D/27
YOU HAVE TO BUY A MASTER REMOTE FROM REMOTES .COM TO BE ABLE TO GET INTO THE SET UP MODE. IT WAS 55.00 ALSO YOU WANT TO GO ON LINE AND DOWN LOAD THE MANUAL IT IS 45 PAGES LONG AND NOT EASY TO UNDERSTAND. SO I CALLED THE HELP NUMBER AND THEY HELPED ALOT GOOD LUCK
Posted on Oct 20, 2011
How do i get my panasonic th37pr9u out of hotel mode....i have tried a few things i found online but no remedy has worked.
Getting out of the hotel mode is very easy. Just go get the Panasonic remote and open your tv. Go near the tv and hold down the V/- button on the television itself. Then use the remote and press the AV button for 3 times. A hidden menu on the television screen will appear. Turn off the "Hotel Mode" from the menu and exit. Do not touch anything from the hidden menu except the hotel mode. Now you can use your tv in normal mode. The remote is required to access the hidden menu so be sure your remote is working and has working or full charged battery before doing the steps above
Read more: I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don`t have the remo... - I just purchased a Panasonic TH-37PG9U TV from a hotel and can`t get it out of hotel mode. How do I get into normal mode? But I don t have the remote control :: Ask Me Fast at http://www.askmefast.com/I_just_purchased_a_Panasonic_TH37PG9U_TV_from_a_hotel_and_cant_get_it_out_of_hotel_mode_How_do_I_get_into_normal_mode_But_I_dont_have_the_remo-qna9315338.html#q5576553 you need your remote,this is the one you need,maybe you can find it cheaper,https://www.amazon.com/OEM-Panasonic-Remote-Control-TH-37PWD8BK/dp/B00NRHAZDU
Apr 21, 2017 | Panasonic Televison & Video
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
Jun 08, 2015 | Televison & Video
How can i unlick philips hotel tv 32hfl5662l/f7
How to switch your hotel Phillips 32HFL5662L/f7 to HDMI if you need to.
(I'm stuck in St Johns, Newfoundland, miles from the downtown....I must be bored)
1. You will need a serial DB9 M-F cable, your PC with a serial port and a terminal program like Hyper Terminal or Putty
2. Set your baud rate to 115200, n,8,1
3. Unplug the AC adaptor connecting the little smart box on the back of the TV. The TV may plug into this adaptor as well, so just plug the TV back into the wall. If you do not, the LCD TV will try to switch back to cable after you select HDMI.
4. Power on the LCD TV and you should see data on the PC screen in readable text.
5. You must send a carriage return after each command <cr> (the enter key on your PC)
6. Use only small letters (no caps)
i - info
u,d,l,r - Up, Down, Left, Right
p - PIP window toggle
To set to HDMI use the following sequence:
i <cr> (menu)
d <cr> (down)
d <cr> (down)
r <r> (right)
then use 'd' and 'r' to select the right input
Jun 13, 2012 | Philips Televison & Video
My model is 32HF7945D/27 I PURCHASED MY T.V. FROM A HOTEL SALE AND IT IS IN LOCK MODE. I HAVE THE ORIGINAL REMOTE BUT CAN'T SEEM TO UNLOCK IT.
Feb 22, 2011 | Philips 20PT6441 20" TV
How to convert a phillip tv from hotel mode to consumer mode without a remote
Nov 22, 2009 | Televison & Video
Can't find menu on hotel tv
YOU WILL NEED THE SPECIAL REMOTE TO DO THIS. AND I THINK SOME OF THEM HAVE ABILITY IN SERVICE MENU TO TURN OFF HOTEL MODE. OR YOU CAN TRY USING ANY PHILLIPS/MAGNAVOX REMOTE WITH THE STATUS BUTTON AND TRY THIS.
PRESS MENU-9-6-5-2-STATUS AND YOU SHOULD BE IN THE SERVICE MODE TURN OFF THE HOTEL MODE
Jan 03, 2009 | Mitsubishi CS-35707 35" TV
How can i unlock philips hotel tv 21ht3302/41?
hey pls help me.. I have this Tv and igit buttons 3,1,9,7,5,3
and the mute button was worked.
but recently
above code doesn't work,as i remeber I put high security in menu.but What can i do now,please help me.
please...
[email protected]
Aug 14, 2008 | Philips 20PT6441 20" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Philips tv
Oct 17, 2007 | Philips 36PT41B TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
