The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
It is clear symptoms of bad optical laser or dirty optical lens. Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player. I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model. Thanks.
sounds like a bad spot in your ribbon cable. it runs form the laser assembly to the circuit brd. you could have some dirt on the sled rails..either way the radio will have to be taken apart..if you can do this yourself the ribbon cable is not too expensive...labor is what gets you..
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged, and if track doesn't jump or restarts in middle of playing back then cd player is just fine, Please check cd creator software settings.
If you're using Windows, then use Windows Media player to rip your music into WMA. If you don't want to do that, use CDdex to rip your music from CD to MP3. The problem probably lies in whatever program your using to rip your music. To your player. http://cdexos.sourceforge.net/
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
